![]() Join Date: Sep 2013
Wilwood adj. prop valve
I want to install wilwood adjustable prop valve....I have disc drum now , can I use the same prop valve if I change to disc disc set up later on?
Re: Wilwood adj. prop valve
I think that's the point to an adjustable prop valve, so it allows you to dial in different brake setups, right?
Depends what you buy, mine is set at 500 for the rear drums and the front is adjustable from 500 - 1000
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Wilwood has an adjustable prop valve that has a dual inlet triple outlet... which I have on my 71. It will work for either disc/drum or disc/disc. The adjustment is only for the rear. You would probably need to make an adjustment (turn the dial) to that prop valve when you did the rear disc conversion.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
