10-05-2015, 11:46 PM | #1 |
3 on the tree to floor shift?
New to this, I have a small v8 with 3 on the tree but want to convert to floor shift. Whats the best easy way and affordable?
10-06-2015, 01:38 AM | #2 |
Re: 3 on the tree to floor shift?
mr gasket 7667a comes complete with everything needed but its hard to find. old school type parts stores and speed shops carry an equivalent.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
10-06-2015, 07:11 AM | #3 |
I bought the Hurst Indy shifter for mine, but I have a 69 Saginaw tranny in mine. I was not pleased with the Mr Gasket that was in mine. It was very flimsy.
Going cheap will get you aggravated as the thing will start shifting weird on you pretty quick. My Mr Gasket was more ittatating the the 3-on-the-tree lingages.
10-06-2015, 09:33 AM | #4 |
There are some simple tricks to fix the Mr. G shifters but since the 7667A is hard to find, you need to step up to Hurst.
Like this. http://www.summitracing.com/int/part...6809/overview/ And you need an installation kit with it too. http://www.summitracing.com/int/part...illocation=int But just remember, the new shifter won't make it faster shifting but it will make it more precise. |
10-06-2015, 11:17 AM | #5 |
Hurst Mastershift is the way to go. Installed one a few months back.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
10-06-2015, 12:44 PM | #6 |
10-06-2015, 12:59 PM | #7 |
Not trying to hijack this thread but I'm wondering if the shift kits and linkages listed and linked above are universal for any 3 speed. Reason I am curious is that I have a 1969 3 speed tranny with a Hurst Indy shift handle and linkage. I am curious if this linkage can be made to fit a 1965 3 speed. I think the 1965 3 speed I have is a shorter transmission.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
10-06-2015, 03:32 PM | #8 |
couple of pics of the mastershift II on the t-16 and the finished install. Plenty of room on my tail shaft mount and with a bench seat
10-06-2015, 05:12 PM | #9 |
10-07-2015, 12:18 AM | #10 |
What transmission should I look for , or can I use the same 3 speed tranny?
10-07-2015, 05:58 AM | #11 |
The problem I ran with my Hurst and the later model synchro (saginaw) transmission, was the emergency brake cross member got in the way. Besides having to move the shifter backwards, I have to cut down the lower ends of the shift controls so they would clear the emergency brake assembly. This also no bench seat as the shift handle wouldn't clear. You can see where the Mr gasket shifter came thru the floor, which required a very bendy shifter handle to clear the bench.
Going back, I think if I still had the original 3 on the tree column, I would have cleaned it up, added some bushings where the rods attach and stayed with a tree shifter.
10-07-2015, 08:47 AM | #12 |
No problems with mine.
