Old 10-06-2015, 05:12 PM   #1
chincha805
49 s10 swap engine question
I am using a 92 s10 for my 49 P/U, if i decide to use the s10 v6 and trans, will i need to move the motor forward or backward, any cutting into firewall, i am trying to go simple as possible and not have to make motor mounts and relocate them.
chincha805 is offline   Reply With Quote
Old 10-06-2015, 10:55 PM   #2
joedoh
joedoh's Avatar
Re: 49 s10 swap engine question
I did my 4.3 V6 4L60E by moving it 5" rearward, it would be through the radiator without moving it. when doing it again, I will move it 6", because I had to run an electric fan, the original engine fan was 1/2" from fitting.
no firewall cut needed on a 5" move and I dont think even 6" would need a cut. depending on where you put your body mounts, you may need a small tunnel for the trans.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 10-06-2015, 11:35 PM   #3
chincha805
did you make motor mounts? any pics.?
Old 10-06-2015, 11:46 PM   #4
joedoh
joedoh's Avatar
lots of pictures in my build thread. what we did was make a plate for the original mounts that moved the engine back 5" and then did the same for the trans, cutting the center and moving it back.
Old 10-07-2015, 07:24 PM   #5
BlueJeep
BlueJeep's Avatar
I moved my 4.3 7" back and no firewall problems. Pictures are in my thread.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
