![]() Join Date: Nov 2007
Water temp gauge replacement. (help finding previous post)
I'm working on rebuilding a cluster. I thought I had found a post before where someone took a gauge from the 73-75'ish trucks and made it work in our 67-72?
Was I smoking something because I cant seem to find that post now? ![]() :edit: Or is it the volt meter that swaps out so it has real numbers rather than just a needle waving around?
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half ![]() 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
Re: Water temp gauge replacement. (help finding previous post)
I'm doing the same right now- replacing the ammeter with a late 70s battery gauge, and a temperature gauge as well. I'm wondering if the different gauge needs a specific sending unit.
![]() Join Date: May 2010
Here's an old thread on the subject. Post 7 by VetteVet has good info on wiring.
http://67-72chevytrucks.com/vboard/s...d.php?t=483509 |
#4 | |
The Older Generation
Here is a thread with info on it. http://67-72chevytrucks.com/vboard/s...d.php?t=630289 LockDoc
Thanks. I had the temp and volt backwards. Its the volt meter that actually gives the direct numbers, not a WAG sweep.
