10-07-2015, 10:30 PM | #1 |
Power Glide ?????
Will 3.08 gears work OK with my 64 power glide??? Its just a driver, don't pull anything with it.. Would put my 70 mph about 2500 rpm......
1964 C10 SWB original 1970 SS El Camino 1964 Impala SS http://67-72chevytrucks.com/vboard/s...d.php?t=649951 |
10-07-2015, 11:03 PM | #2 |
Re: Power Glide ?????
That's what I just put in mine, I think it should be about the best ratio.
10-08-2015, 12:16 AM | #3 |
Rollin' Old Skool
That's what mine has. I wanted 5-lug & better gearing for the highway until I bolt up a 700R-4 someday, so we swapped in a '72 Chevy truck rear with that gear ratio. Like you, I just wanted a cruiser. I haven't done much driving with that setup, as we tore the truck down for a front end rebuild shortly afterward. I did have a chance to do a little highway driving though, & it was definitely a noticeable difference compared to the factory rear end with 3.73's
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
10-08-2015, 06:25 AM | #4 |
Moderator
Here are some web pages with calculators on them:
http://www.csgnetwork.com/rearendgearcalc.html http://www.angelfire.com/fl/procrastination/rear.html Tire Diameter info: http://ejelta.com/tiresize/index.htm...eel=&maxwheel=
10-08-2015, 08:21 AM | #5 |
They have worked that way for decades. Go for it.
10-08-2015, 08:39 PM | #6 |
Moderator
My 65 Impala 327/Glide has stock 3:08s. Drives great, no problem on the highway at 70.
