Old 10-08-2015, 08:27 AM   #1
71custominworks
Junior Member
Wanting to learn suspension.
Would like a specific book or Web address that I can go to, to learn how to figure out the geometry, ride height, and material needed to build a parallel or triangulated 4-link. I've tried googling and it's a lot of four wheel drive applications. Video would be great to. Thanks for any help.
71custominworks is offline   Reply With Quote
Old 10-08-2015, 01:26 PM   #2
tinydb84
tinydb84's Avatar
Re: Wanting to learn suspension.
Depending on how in depth you want to get:
Make it Handle (the long and awesome thread on here): http://67-72chevytrucks.com/vboard/s...d.php?t=419251
Ride Height discussion (with a lot of really good info from Rob-No Limit): http://www.pro-touring.com/threads/1...01-Ride-Height
Basic Rear Suspension Set Up: http://www.pro-touring.com/threads/1...my-3-link-bars
Way too in depth front suspension: http://www.pro-touring.com/threads/1...ck-Performance
If you want an actual book I really like: Chassis Engineering by Herb Adams Chassis Engineering: Chassis Design, Building... Chassis Engineering: Chassis Design, Building...
As for size/material for the set up, most venders will have universal kits. As long as you are using them as intended you should be fine.
David
Instagram: myfabguy
Old 10-08-2015, 07:55 PM   #3
71custominworks
Junior Member
Thank you
