10-08-2015, 12:58 PM | #1 |
Speedo and Gauge rebuilder?
Hi - Can anyone recommend a good shop for rebuilding/restoring my speedometer and gauge cluster.
I'd like a restoration shop that can correctly calibrate the speedo for my wheel/tyre combo and one that can modify the gauge cluster to have the correct ranges for my engine. Thanks in advance for any help Mack |
10-08-2015, 01:19 PM | #2 |
Re: Speedo and Gauge rebuilder?
Jim Carter rebuilds clusters. You can buy an inline adapter for different gear ratios and tire sizes.
10-08-2015, 02:12 PM | #3 |
Hollister Road Co.
http://www.classicgaugeandcluster.com he did a real nice job on my 47 gauges and converted the amp gauge to a volt meter. here are a few before and after.
He is also a board member |
10-08-2015, 02:39 PM | #4 |
Tom did great work but unfortunately had decided to discontinue operations.
http://67-72chevytrucks.com/vboard/s...d.php?t=682051 |
10-08-2015, 03:44 PM | #5 |
Thanks for your replies. I'd already sent Classic gauge and cluster an email as I'd seen his work. Hopefully he'll get set up in a new shop at some point in the future as that's some lovely work.
Thanks PaulspickupParts- I'll look into Jim Carter 👍🏻 |
10-08-2015, 04:25 PM | #6 | |
Hollister Road Co.
10-08-2015, 10:21 PM | #7 |
I used Auto Instruments, Martinsville, VA. I had them do a mechanical refurbishment, nothing on the cosmetics. They fixed my '59 cluster up, working good now.
2018 BMW R1200RT 2013 Aprilia Tuono 2012 Ford Flex 2011 Ducati Hypermotard 1959 Chevy 3100 |
10-14-2015, 07:04 PM | #8 | |
tbone1964 calibrated my 58 speedo after returning 3 repops for being garbage otherwise that's who i would have recommended
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
