Old 10-08-2015, 07:13 PM   #1
'65 chevy lover
Welding up the holes where side trim was.
I've been thinking about welding up the holes where the side trim goes. Is this an easy thing to do? Does it cause a lot of extra work?
'65 chevy lover is offline   Reply With Quote
Old 10-08-2015, 08:04 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Welding up the holes where side trim was.
Take a nail, slip it in from the back side, spot weld, cut off shank, grind smooth.
66 C20 Service Truck:
Old 10-08-2015, 09:35 PM   #3
cru_zn_29
cru_zn_29's Avatar
Don't get the metal too hot. I have used a hole punch 1/4 or 5/16 or what ever size your hole is and a scrap body panel. Punch out the plug put pug in the hole i tig weld them in.Small welds then let it cool completely Don't get in a hurry you will have a mess. Yes it is a lot of work.
cru_zn_29 is offline   Reply With Quote
Old 10-08-2015, 10:10 PM   #4
aotte1
If you have the parts off or have access to the back of the panel to weld from, you can use a 1/8 inch thick piece of pure copper held on the face of the panel. This will give you a very close to flush weld. Once the copper cools it will fall off. Weld to the metal, not the copper, puddle runs onto the copper.
Good idea to practice on scrape metal a couple times, get technique down first.
aotte1 is offline   Reply With Quote
Old 10-08-2015, 11:09 PM   #5
Fredthecat
Edited by Forum Staff
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Fredthecat is offline   Reply With Quote
Old 10-08-2015, 11:28 PM   #6
Brad54
Brad54's Avatar
x2 on the copper.
I use a piece of plumbing copper from Home Depot. Hammer one end flat, round the corners, and then put a bend in it to make a spatula.
Works like a charm.
It WILL become a heat-sink though and the handle get hot... I drilled a few holes through the tubing, like the screen on semi truck stacks or the shield on a .50 cal machine gun. They radiate the heat away and you can hold it with your bare hand while welding.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 10-09-2015, 12:00 AM   #7
argonaut
argonaut's Avatar
I used a cheap copper welding spoon from harbor freight. I didn't hear about the nail trick until after I did my doors and fenders. Sounds interesting and next time I'll try it. Just be sure to used raw nails, not coated or galvanized.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 10-09-2015, 08:57 AM   #8
Improbcat
Improbcat's Avatar
I bought a cab with the side trim to replace the one without on my truck. There is how I welded up the holes.
Circle cut from sheet metal, held in place with a welding magnet.
Welded up and ground smooth enough for filler.
I have to say though, the nail trick sounds interesting.
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures)
SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD
Improbcat is offline   Reply With Quote
Old 10-09-2015, 08:11 PM   #9
scum1
scum1's Avatar
i used some steel screws that fit the holes on mine. turned out good. pretty easy as well.
scum1 is offline   Reply With Quote
Old 10-13-2015, 09:33 PM   #10
'65 chevy lover
Idea for plugging holes for side trim
I just got an idea for plugging the holes for side trim. The idea is to use metal pieces about 1/2-1" bigger than the hole and using something like J-B weld to stick it in place and then, filling the hole with more J-B weld or bondo. This would avoid the heat of welding and the potential for warping the panel. What ya'll think about that? Good idea or....Dumb idea?
Old 10-13-2015, 09:44 PM   #11
'63GENIII
'63GENIII's Avatar
Re: Idea for plugging holes for side trim
Duct tape backing and Bondo? LOL, just messing with you.
I have heard of guys taking a piece of thick flat copper, holding it tight against the backside of the hole and then welding the hole up. The weld doesn't stick to the copper and the copper helps to keep the hole from blowing out while you're welding. Ive never tried it myself but for the cost of a small piece of copper (maybe electrical buss bar), I'd be willing to try it.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-13-2015, 09:45 PM   #12
thunder71
thunder71's Avatar
I would not use jb weld for anything...your plugs will fall off then you have holes...weld them up slow
_____________________________________
66 C10 shortbed stepside KEEPER
66 C10 longbed stepside SOLD
69 C10 shortbed stepside SOLD
71 C10 custom deluxe long fleetside SOLD
thunder71 is offline   Reply With Quote
Old 10-13-2015, 10:01 PM   #13
LostMy65
LostMy65's Avatar
There's some ideas in this thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=684723
Old 10-13-2015, 10:13 PM   #14
NevEno
NevEno's Avatar
You can buy a copper plate with magnets in it.. Just go slow.. I used one on my door skins without warpage
You can find me on Instagram @neveno_cten
NevEno is offline   Reply With Quote
Old 10-13-2015, 11:45 PM   #15
'65 chevy lover
Yeah, I kinda thought it wouldn't be a great idea, but might be worth a shot. I just really want to go without the side trim but, don't want to screw up the panels and cause myself a LOT of extra work. Thanks to all for the input!
Old 10-14-2015, 12:19 AM   #16
markeb01
Senior Enthusiast
markeb01's Avatar
Here's an older thread that may be helpful:
http://67-72chevytrucks.com/vboard/s...hlight=jb+weld
I've used JB Weld all over my truck and it works great, and permanently. The key to success is cleanliness. Everything needs to be spotless, and JB Weld sticks permanently.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 10-14-2015, 10:10 AM   #17
joedoh
joedoh's Avatar
I used to shave the emblems on my minitrucks with jb weld and the change in my pocket haha. I think there was even a magazine how-to written on it.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 10-14-2015, 01:27 PM   #18
LostMy65
LostMy65's Avatar
I do remember someone posting about using a dime.
Steel on the outside and copper inside.
Old 10-14-2015, 04:21 PM   #19
Brad54
Brad54's Avatar
It's not even that difficult: Just go to Home Depot or any other hardware store and buy a 1-foot length of copper tubing and hammer one end flat. Then put a 30-45 degree bend in the flat piece, and done.
If you want to go OCD on it, found the corners of the flat end, and then drill a few 3/8-inch holes through the handle after the flat to radiate the heat away from your hand. (it'll wick the heat up to your hand otherwise.)
Without the holes, it gets hot even through gloves after a while.
With the holes you can hold it bare-handed and weld all day.
-Brad
Old 10-14-2015, 06:39 PM   #20
thunder71
thunder71's Avatar
Yes if you can't weld then glue it together should last forever
Old 10-14-2015, 09:39 PM   #21
'65 chevy lover
Thanks a lot to all for the advise! I can do the welding, no problem but, was just thinking ( sometimes that's dangerous I know...LOL) that using an epoxy type adhesive would mean I wouldn't have to worry about screwing up the panels with heat.
