Old 09-13-2003, 02:20 PM   #1
beeroh
engine block code?
what does CFD 207 mean, I found this code on the side of the engine block.
84 Silverado,
beeroh is offline   Reply With Quote
Old 09-13-2003, 03:05 PM   #2
beeroh
it means Central Foundry Division casting 207
engine casting number
14010207
80-85 350 block
84 Silverado,
Old 09-13-2003, 03:06 PM   #3
Big Paul
Iamnotanofficerofthelaw
Big Paul's Avatar
Did you get it off one of the pass. head pad?
There is a number at the back of the block on the drivers side. You will probably have to climb up in there to check it out. Its right above the transmission and behind the valve cover.
If you get it check here:
www.mortec.com
You should be able to find out what engine you have and some specifics about it.
~Paul~
'96 C1500 Silverado- Vortec 5.0L/Exhaust/Stock
'87 S-10 Ext Cab- 2.8L/700r4
KIA Caught fire 12/7/03
Big Paul is offline   Reply With Quote
Old 09-13-2003, 03:07 PM   #4
Big Paul
Big Paul's Avatar
Ahh you beat me to it.
~Paul~
