Old 10-09-2015, 12:59 AM   #1
BKWDco
Steering column joint u-joint help.
I picked up a steering column from 76 chevy van for my TF rebuild.
Can anyone who has used one of these columns point me towards a u-joint thats compatible with a DD shaft?
thank you
BKWDco is offline   Reply With Quote
Old 10-09-2015, 08:20 AM   #2
HUSSEY
HUSSEY's Avatar
Re: Steering column joint u-joint help.
See "How to Determine the Correct Universal Joint Size" here http://www.flamingriver.com/index.php/service/tips.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 10-09-2015, 11:43 AM   #3
BKWDco
Thank you!
Old 10-09-2015, 01:21 PM   #4
OrrieG
OrrieG's Avatar
Borgsen also has good tutorials and design information. I used a modified astro van column to transition from the column and box splines to DD. Not as pretty as the Borgsen, but plenty stout.
OrrieG is offline   Reply With Quote
Old 10-09-2015, 02:45 PM   #5
RockinKees
RockinKees's Avatar
I had a mid 70's Chevy Van tilt column and that had a 3/4-36 spline...
There are U-joints for 3/4-36 spline to 3/4-DD.
But again, that's what I got.
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 10-09-2015, 04:06 PM   #6
1958Warrior
1958Warrior's Avatar
What are you going to connect it to? What are your plans for the front end ? straight axle? IFS ? power steering?
If your going to keep stock axle , you will need to replace or modify existing steering box.
OrrieG has a good example, if you can get the steering shaft to go along with the column that will help a lot.
If going w/mustang II may need a double U joint and a support also if I recall right, Someone with a MustII set up can chime in ,
I'm matching my original column to my Camaro gear box on my Camaro front clip now.
I'm using every thing Camaro up to the column then using a 3/4 x3/4 DD U joint I just received off Ebay, real nice quality Beefy piece, and nice $ at $28
http://www.ebay.com/itm/Black-Univer...1b8fc2&vxp=mtr
1958Warrior is offline   Reply With Quote
Old 10-09-2015, 06:55 PM   #7
BKWDco
Thanks for the info. After further research I think it is the 3/4 36 spline. But I will count this weekend.
I put in a TCI front end with a manual rack last summer. And like and idiot I skimped on the column. I bought a unit from one of the big websites, that had their name on it($300=/-). It never felt solid, then a week after I got it on the road the tilt mechanism broke. It would pop in and out of position with the smallest amount of pressure. But, I was so excited to have it back on the road, I couldn't let it sit while I figured out the issues.
So a year later...I made it to the junkyard and pulled a great column for $65. SO I am finally right-siding that mistake. And with your help, I think I know what joint to get. thank you
