Old 10-09-2015, 02:37 AM   #1
fredscarryall
fredscarryall's Avatar
What radiator for s10 conversion
I see everyone posting pics of radiators on there 48 to 53 s10 conversions. But seems no one is saying what radiator they are using. I need a radiator with a passanger lower hose and driver upper hose. I saw this 68 mustang one but the upper one is on the wrong side. I know I could buy this one and have a radiator shop charge me $75 and wait 2 weeks to move the upper over.But ii would rather buy one ready to go.
fredscarryall is offline   Reply With Quote
Old 10-09-2015, 07:42 AM   #2
Atommik
Atommik's Avatar
Re: What radiator for s10 conversion
I use a Champion radiator, 2 core 19" wide 21" tall outlets where you need them, under $200. Never had any trouble with it in three years! Found it online. (51 Chev, S10, 327 sbc) Available with or without trans cooler.
Atommik is offline   Reply With Quote
Old 10-09-2015, 08:10 AM   #3
HUSSEY
HUSSEY's Avatar
I'm using the same size as Attomik mentioned. I got mine from Summing, SUM-381324, the fan is a Spal, P/N IX-30100400 which is the thinnest fan I cold find.
There's some pics of it in my build thread starting at post 75 (see link in signature).
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 10-11-2015, 10:43 PM   #4
youngrodder
youngrodder's Avatar
I used one from a Toyota landcruiser. The brand that I bought is a Champion. Here is a similar one.
http://http://www.ebay.com/itm/1958-to-1980-Toyota-Land-Cruiser-Lightweight-Aluminum-Radiator-3-Row-Core-/201081986383?fits=Model%3ALand+Cruiser&hash=item2ed16b9d4f&vxp=mtr
Works fine. I ended up upgrading to a 4 core because a 3 core ran warmer than I would have liked. I'm sure a 3 core should work OK for you
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 10-11-2015, 10:59 PM   #5
fredscarryall
Youngrodder do you have a pic of the radiator In you truck
Old 10-12-2015, 12:01 AM   #6
joedoh
joedoh's Avatar
we modified the inner fenders, made mounts, and used the stock s10 radiator on my truck. nice because the trans cooler and oil cooler are included with the stock rad.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 10-12-2015, 08:09 AM   #7
youngrodder
Yes, but I need to dig them up. I will see what I can find.
Marc
Old 10-14-2015, 08:40 AM   #8
sam86
Marc
Did you have to modify anything to get this to work?
sam86 is offline   Reply With Quote
Old 10-14-2015, 12:12 PM   #9
bob Scott
I believe the first gen Mustang radiators are also used.
bob Scott is offline   Reply With Quote
Old 10-14-2015, 07:29 PM   #10
Sim6
Sim6's Avatar
I used an aluminum one from Speedway Motors 19x22. $115.99 part #917347
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 10-14-2015, 08:38 PM   #11
sam86
Did you have to do any modifications to make it fit?
Old 10-15-2015, 11:36 AM   #12
Sim6
Sim6's Avatar
I followed Skymangs deal. you have cut the lip off the inner channel and weld in a 4" channel into the bottom. Skymangs uses 67-72 radiator cushions and makes brackets.
Old 10-15-2015, 09:18 PM   #13
FiftyTwo
FiftyTwo's Avatar
I used a 1964-66 Mustang V8 radiator, fits great, works great and cost about $130.00
Almost a bolt-in deal.
FiftyTwo is offline   Reply With Quote
Old 10-16-2015, 04:48 AM   #14
fredscarryall
Thanks Marc
I think the 1958 to 1980 land cruiser radiator will work perfect. I am either going to get the 4 row or 2 row with one inch tubes. Here are the measurements. I also like the fact that the tanks are at the bottom and top. The only thing Is the inlet and outlet are 1 1/2 inch but they line up perfectly for a small block chevy
Old 10-16-2015, 04:50 AM   #15
fredscarryall
Here a picture with a fan and shroud
Old 10-16-2015, 08:06 AM   #16
youngrodder
Thanks Marc
Fred-
Your welcome. If you go with a 2 -3 core you shouldn't have to make any modifications. When I switched to the 4 core I had to notch the front cowl and push the radiator forward. I'm running an LT1 though and I didn't have a ton of space between the engine and the radiator to start with.
Good luck
Marc
