10-09-2015, 03:35 PM | #1 |
Rear brakes question
My 86 GMC is doing something I have never seen before on a vehicle. I recently went through the brakes on the rear, new steel lines on the axle, new wheel cylinders, brakes, drums, and parking brake cable on the driver side. Now mind you the truck isn't sitting on a hill, but when we cracked the bleeder screws open, for some reason they bleed themselves. You can walk up to the master cylinder, and watch the fluid go down, and come out the bleeder screws. Is there something wrong with my master cylinder or something/ I've never seen this before. It has the hyrda-boosted brakes on it. Seems to stop fine, was just wondering.
10-09-2015, 08:06 PM | #2 |
Re: Rear brakes question
That's normal.
10-09-2015, 08:18 PM | #3 |
Enjoy it, it's known as gravity bleed.
Posted via Mobile Device |
10-10-2015, 07:12 AM | #4 |
That just means you have a good working system . This is a common way some people bleed there system . As Toddoky said ,its called gravity bleeding.
10-10-2015, 02:42 PM | #5 |
Thanks guy's. I had heard of Gravity bleed before, but never experienced it. I've always had to have help, and do the peddle pump thing, or use a power bleeder. I was just shocked when it did it.
