EZ Cool Insulation - anyone used?
Was thinking of ordering some EZ Cool Insulation (http://www.lobucrod.com/) to put on the floor of my '70 cab to cut down on noise and heat. Has anyone used it? How is it? Is it durable (a stock type vinyl floor mat will go over it)?
Also, I'm thinking the 4' x 25' should be enough, correct? Thanks |
Re: EZ Cool Insulation - anyone used?
If it is what I think it is, this is the same stuff
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Hmm, not sure. Someone who's used it will have to chime in. If so that's a much better deal.
I used EZ cool on my '70 4x10 covered the firewall floor and back wall. I put down FatMat first. Haven't got it on the road yet so I can't help with how well it works just yet.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
Check out this thread. I'm still happy with the results. http://67-72chevytrucks.com/vboard/s...d.php?t=624031
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
I used it on my son's 71 GMC because the guy who sells it is local and I see him at all the swap meets. I'm not sure it is any better than the cheaper alternatives like the insulation sold at Lowes and Home Depot. I think anything you use would make a noticeable improvement in these old trucks.
"Negative people always seem to have a problem for every solution" |
