Old 09-13-2003, 05:02 PM   #1
theo70
COMING SOON...
theo70's Avatar
C/10 badge installation
So what has to be removed from the engine bay to put on the c10 emblems?
theo70 is offline   Reply With Quote
Old 09-13-2003, 05:25 PM   #2
hank
just put on my cheyenne emblems.
did mine with my inner fenders off and unbolted the bottom bolt of the fender that you're attaching to. you will be able to flex the fender out just enough to be able to bolt it on...
or just order the clips that attach the chrome trim piece that goes just above the tailgate handle...they will make the job really easy...just press them on the emblem posts, then press the emblem in the hole. no need to remove anything.
wish i knew this before i did it the hard way.
hank is offline   Reply With Quote
Old 09-13-2003, 08:18 PM   #3
70blazer
70blazer's Avatar
Anyone know where to order those clips from? I am about to install my new emblems.
1967 Suburban, my kids call it the SuburBEAN cuz its long and green.
70blazer is offline   Reply With Quote
Old 09-13-2003, 10:22 PM   #4
casey
casey's Avatar
there called barrel clips, your local auto body paint store should have them, maybe even a regular parts store
casey is offline   Reply With Quote
Old 09-14-2003, 08:00 AM   #5
70c10
67-72 Addict!
70c10's Avatar
I didn't know about this method either. I unbolted the inner fender on the pass. side and fit my arm in on the drivers side., but mine are held in by the front nut only. In hindsight I wish I would have just mig welded the holes closed for a smoother look.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
