Old 10-09-2015, 07:20 PM   #1
Larry64
3rd brake light
Putting in a Suburban 3rd brake light. Have the light grounded. Where do you attach the wire to activate the light when braking?
Never drive faster than your Guardian Angel can fly
Larry
Larry64 is offline   Reply With Quote
Old 10-09-2015, 08:02 PM   #2
PGSigns
PGSigns's Avatar
Re: 3rd brake light
I would pick it up off the brake light switch.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-09-2015, 08:06 PM   #3
Larry64
Re: 3rd brake light
Jimmy the brown, green or yellow wire.
Larry
Old 10-09-2015, 08:09 PM   #4
joedoh
joedoh's Avatar
Re: 3rd brake light
white at the switch. dont use the brown, its parking lights, dont use the yellow or green those are turn/brake, your third brake light will flash with whichever turn signal wire you use.
as jimmy said, get it at the switch, it is the white.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 10-09-2015, 08:10 PM   #5
PGSigns
PGSigns's Avatar
Re: 3rd brake light
With a test light one side is hot all the time and the other side the switch will only be hot when the pedal is pushed. That is the side you need.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 10-09-2015, 08:11 PM   #6
Larry64
Re: 3rd brake light
Larry
