Old 10-09-2015, 07:36 PM   #1
John Pasinski
John Pasinski's Avatar
BB PS Remote Res.w/ Extension arm?
Usually I go into the archives and find my answers. This time I haven't found what I'm searching for.
I have a 1972 402 BB. I added PS as the truck was never ordered with it.
I'm also in the process of adding an auxiliary battery.
I read somewhere that an EXTENSION ARM is required for the remote reservoir when an auxiliary battery is installed due to the additional junction block I assume.
Is this true? If so, does anyone have a photo? I may need to find one.
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
Old 10-09-2015, 07:55 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: BB PS Remote Res.w/ Extension arm?
I think the 68s came with the extension or if you had the aux. battery. I can post up a pic later if no one else does.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-09-2015, 10:58 PM   #3
Livrat
Member #1049
Livrat's Avatar
I do believe Eric is correct, I have only found them on 68's, not sure about the other years,
Here is the one on my 68
Livrat is offline   Reply With Quote
Old 10-10-2015, 08:18 AM   #4
John Pasinski
Livrat.....Would you post photos of the junction block locations, as well as the squirts reservoir location on your truck?
I'm trying to determine the locations of these items.
Old 10-14-2015, 11:07 PM   #5
Livrat
Member #1049
Livrat's Avatar
John,
For some reason I totally missed your reply asking for pictures, Sorry.
Unfortunately my truck is a "Mutt", I installed the aux battery tray but never did wire up the relay and junction block.
Here are a couple of pictures of my windshield squirter bottle mounting, again I just located it where it seemed to fit and not to any factory specs.
Old 10-15-2015, 06:03 AM   #6
John Pasinski
Originally Posted by Livrat View Post
John,
Thank you, much appreciated. I'm pretty sure I can figure out the location of the bracket mount from my assembly manual.
Although it appears the right side mount location uses a different bottle bracket. It looks like there's an "S" style modification to the right side bracket. Am I correct?
Perhaps that style bracket is required to clear the inner fender?
Old 10-15-2015, 11:18 AM   #7
Livrat
Member #1049
Livrat's Avatar
Now that you mention it, it does appear to be a stock truck bracket with a modification, I do believe it is a factory GM bracket but I do not remember exactly what car/truck it came off of, Its one I had laying around, At the time I built the truck I had built/parted a bunch of 67-69 Camaros, 64-72 Chevelles, ElCamino's and 70-72 Monte Carlos.
Maybe someone that knows what it came off of will chime in?
Old 10-15-2015, 04:05 PM   #8
Classic Bowties
Always on the hunt...
Hey Mark, your pictured pass. side mounted washer bottle bracket looks like the factory OE truck bracket used with the optional TP2 auxiliary battery setup. Check out the below diagram and also an original TP2 tray and bracket setup that I sold a few months back. I also agree with you and Eric on the 68 style p/s reservoir ext. bracket subject, my original 71 & 72 big block trucks both with the aux battery setups have the p/s reservoiir mounted directly to the drivers side fender. Mel
Classic Bowties is offline   Reply With Quote
