![]() Join Date: Apr 2006
Holley parts
Complete Brand New Holley EFI Setup. Includes everything shown in the first photo, except second set of injectors. Aside from the coils, the package includes everything you need for a fuel injected Chevrolet LS3 (or other LS with LS3 cylinder heads). Same setup is used on Chevy’s COPO Camaro (the best of the best for EFI control). All parts are brand new, undamaged and in the original Holley boxes.
Over $6300.00 in Parts. I'm Asking $5100 plus actual Shipping. Ill take paypal if the 3% is paid. Parts list is as follows: Main Harness, Holley 558-103 Main Power Harness, Holley 558-308 Coil Harness, Holley 558-309 Injector Harness, Holley 558-201 NTK Wide Band O2 Sensor, Holley 554-100 Fuel PSI Transducer, Holley 554-102 Coolant Temperature Sensor, Holley 534-10 Air Temperature Sensor, Holley 9920-107 Fuel Injectors, 42#, Holley 522-428 Fuel Rail Kit, Holley 534-203 Throttle Cable Bracket, Holley 20-149 Dominator ECU, Holley 554-114 105 MM Throttle Body, Holley 112-581 LS3 Hi Ram Intake, Holley 300-117BK Hi Ram Plenum, Holley 300-232BK Throttle Body Gasket, Holley 508-20 Dominator Fuel Pump, Holley 12-600-2 Billet Fuel PSI Regulator, Holley 12-848 5.7” Touch Screen LCD Controller, Holley 553-103
Kirk 72 Blazer CST 4wd highlander |
| Bookmarks |
