View Poll Results: What'cha think?
So crazey it may work 3 75.00%
Not worth the time 0 0%
No idea, but is sounds cool 1 25.00%
Voters: 4. You may not vote on this poll
Old 09-13-2003, 05:17 PM   #1
Blackhawkdc
440 american Horses
Blackhawkdc's Avatar
big block fuelie idea
anyone ever thought about this? Take the upper and lower intake and throttle body from a '95 or newer 454 in a GM truck. Polish the heck out of the intake runners, bolt on an oversized throttle body. bigger injectors and a stand-along fuel control system. I've been thinking of unique ways to put fuel injection on my big block 496 stroker when I build it and install it in the truck. The fuel injection system has to have 8 injectors and be able to handle 550+ horse. Any other ideas?
Seth Petro
1969 Chev Short Step
425hp 350, TH400, big tires, fast truck
1979 Pontiac Trans Am
1991 Saturn SL1 - gas mileage! (and free)
1977 Buick LeSabre - for sale
May America bless God, and may God bless America
Blackhawkdc is offline   Reply With Quote
Old 09-13-2003, 07:21 PM   #2
cdowns
cdowns's Avatar
hilborn
Old 09-13-2003, 10:39 PM   #3
nate68
at least a holley c950 system or something
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 09-13-2003, 10:44 PM   #4
miket
miket's Avatar
Other than what you mentioned...there are several F.I systems out there as a bolt on/in unit....Holley makes one and few others...I am sure street and performance does too.
Ala Ramjet 502!!!
I thinks it's a cool idea....
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 09-13-2003, 10:47 PM   #5
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
I wouldent mess with stock stuff you can buy a kit or peice it together you can buy the injector bungs and weld them into an intake and then get a throtle body, injectors, fuel rails and computer and harness from accel. Just a thought.
GMC JUNKIE TOO is offline   Reply With Quote
Old 09-13-2003, 11:00 PM   #6
CoryM
You are going to need an aftermarket ECU which are not cheap. I am deciding whether to carb or EFI my next engine. If I go efi it will use an aftermarket ecu with custom rails/intake and a 4 barrel TB like GMCJunkietwo suggested. I also HIGHLY suggest you break in an engine with a carb, then go to EFI unless you are an efi tuning god. Your engine will thank you for it. I have spent a LOT of time tuning with a FAST ecu and gotta admit its just plain cool. $1800usd for the ecu though. And the O2 sensor is about $450usd if it fails (has to be matched to the ECU). THats the only part I dont like about it.
COryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada
http://www.geocities.com/chevroletc1070
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
