Old 10-10-2015, 02:51 PM   #1
Jimal
Jimal's Avatar
Transfer case shifter pivot bushing?
The shifter on the T221 in my '65 K10 is loose. In particular it slides side-to-side, and generally rattles. I'm assuming at this point there are rubber (or other) bushings missing from the pivot shaft, which is allowing for all this movement and the resulting rattle. Is there a source for pieces like this or am I going to have to make something up?
Jimal is offline   Reply With Quote
Old 10-10-2015, 03:15 PM   #2
61K10
61K10's Avatar
Re: Transfer case shifter pivot bushing?
there is a spring that goes between the shifter and the mounting bracket. It keeps the shifter against the outer c-clip.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-10-2015, 06:53 PM   #3
Jimal
Jimal's Avatar
Like a spring washer?
Old 10-11-2015, 12:50 PM   #4
61K10
61K10's Avatar
no a small coil type spring, but the spring washer might work. maybe 2? A lite wait spring from a hardware store--cut a few coils off--should work.
1961 chevy K10
Old 10-12-2015, 12:14 AM   #5
'63GENIII
'63GENIII's Avatar
Thats funny, mine is welded to the hump. Thought they came like that. Damn, another thing to fix now.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-12-2015, 11:53 AM   #6
Jimal
Jimal's Avatar
Is there another spring that puts tension on the shifter, fore or aft? Or a rubber bumper somewhere?
Old 10-12-2015, 12:19 PM   #7
61K10
61K10's Avatar
Jimal--there was none on mine. Diagram for adjusting linkage doesn't show any.
63GEN---welded to the hump?
1961 chevy K10
Old 10-13-2015, 02:05 PM   #8
Jimal
Jimal's Avatar
Hmm. I wonder if it is just the accumulated slop in the system. I'll have to tinker.
Old 10-14-2015, 12:03 PM   #9
61K10
61K10's Avatar
i replaced all the pins in the linkage with bolts with lock nuts to get rid of most of the slop.
1961 chevy K10
Old 10-18-2015, 01:40 AM   #10
maxwoof
I put all new pins in my linkage as well. In addition, wherever I could, I drilled out the linkage to 1/2" and pressed in 1/2" x 3/8" bushings. This took care of most of the slop and rattling.
maxwoof is offline   Reply With Quote
