Old 10-10-2015, 05:19 PM   #1
tibado
My new 67 K10 - Anyone know who built me?
Be gentle, new user first post.
Just bought this off of Ebay a few months ago and am starting to go through it and 'correct' any issues, and was wondering if anyone on the board recognized it and may help finding the builder/restorer. I know the first owner was in WA, then it went to AZ to a broker in late 2014 then to the guy I bought it from in AZ this year.
What I know so far:
VIN = KE147Z126955
K = 4x4
E = V-8 Gasoline
1 = 1/2 Ton
4 = Pickup with Cab and Bed
7 = 1967
Z = Fremont California
126955 = Serial Number"
Engine - GM 350/290hp crate
Trans - SM420 4 speed with granny 1st gear
Transfer - Rockwell T221
Rear - 3:73 Gear
Some of the work I've already done:
1. Replaced the broken stereo with a Retrosound unit
2. Replaced the 750CFM (way to big and poorly adjusted) with a 600CFM
3. Replaced the Stock Engine X-Member with a DIY4x so I can get access to the oil pan without having to remove the engine... and upgrade to the round vs pancake motor mounts. Ill post the pics and process if anyone is interested.
4. Replaced the messed up front oil pan seal (see below) with a FelPro one piece dry seal, they thought it was the rear main causing all the oil leaks from the engine, its fine, looks like someone messed it up installing it.
5. Replaced the oil pan, valve cover and air cleaner
6. Replaced the Plugs and wires to move them to the top of the engine
Work in progress:
1. Replace the cracked intake that's leaking coolant into the block, this is the main reason they sold it, they thought the motor was going south. I found out that no damage had been done, luckily...
2. General cleaning, documenting and fluid changes in the trans, transfer, diff's etc...
3. Replace the right front wheel well, looks like a battery let loose and ate through front lower section. Its the ONLY issue with the whole body.
4. Find a good trans guy to pull it out and do a rebuild/re-seal to fix a minor leak.
5. Replace the worn trans, transfer, mounts and bushings, they look like they are all of the 48 years old and I cant figure out why with so much work put into the truck they didn't replace them all at the time they were doing the build...
Pics:
tibado is offline   Reply With Quote
Old 10-10-2015, 05:58 PM   #2
71swb4x4
71swb4x4's Avatar
Re: My new 67 K10 - Anyone know who built me?
Nice looking truck!! I think you forgot to tell us about the other cars in the garage though...
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-10-2015, 06:03 PM   #3
tibado
I wish it was my garage... these pics are from the prior owner, and its the main reason I purchased the truck 'site unseen' after spending some time talking with him over a few weeks I got a real good vibe, another true 'Car Guy'. And I was right... great quality truck for a great price with only a few issues that I'm working to correct.
Old 10-10-2015, 06:27 PM   #4
undertaker72
undertaker72's Avatar
that garage looks like its loaded with muscle------muscle heaven
undertaker72 is offline   Reply With Quote
Old 10-11-2015, 11:08 AM   #5
enigma
Hello beautiful!!!!!!! I can only pray that mine turns out that nice looking.
enigma is offline   Reply With Quote
Old 10-11-2015, 02:53 PM   #6
19silverado77
Very clean and we'll done truck
19silverado77 is offline   Reply With Quote
Old 10-12-2015, 08:17 PM   #7
CanadianK10
CanadianK10's Avatar
Can't help ya on who built it but they did a nice job. Great looking truck!
1967 K10 292, SM65 Transmission & NP205 Transfer Case
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=605048
CanadianK10 is offline   Reply With Quote
Old 10-19-2015, 11:45 AM   #8
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Same here no idea who built it but awesome looking truck looks pretty clean! Keep up the good work going to make a fun cruiser.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 12-27-2015, 11:44 PM   #9
El Dorado Jim
Love your beautiful truck!
El Dorado Jim is offline   Reply With Quote
