Front suspension drop failure
I have 2 1/2" drop spindles and cut 2 full coils off the stock C/10 springs. Truck is fully bottomed out with tires resting on the top of the inner fenders. Clearly 2 coils is way too much. Time for new springs.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
Re: Front suspension drop failure
looks good tho id just pull the inners for now lol
Post Whore
![]() Join Date: Aug 2014
You shouldn't be cutting coil springs to begin with.
Nah... Cutting springs is fine. Do it with a sawzall or cutoff wheel, not a torch and you'll be fine. 2 full coils is pretty aggressive, most people do just one and get around 2" of ride height with a moderately stiffer ride. Chopping a coil off and relocating the shackles and hangers is a near zero cost way to get lower.
You might want to try a smaller size tire. That's the way my truck sits and ive got a 225/70 15 and it still rubs on hard cornering. had a set of 225 75 15s up front and it was about the same but rubbed a tad more(Hercules terra trac) I had 225 75 bfg ta tires that for some reason didn't rub though.
If you're buying springs, buy 1-ton springs. It adds spring rate so you can ride low with less bottoming out --- but only cut a coil or so off (I cut a coil, then kept trimming 2" off the end until it sat at the height I wanted).
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#7 | |
Collector of Projects
Bar Diameter - Inches 0.78 End Type 1 Tangential End Type 2 Pigtail Free Height - Inches 13.64 ID - Inches 3.68 Installation Height - Inches 10.00 Load - lbs 3155.00 Spring Rate - lbs per inch 843.00 Spring Type Constant Rate Alternate/OEM Part Number(s): 328096, 328097, 328150, 328151, 3933259 MOOG 6454 1 ton Bar Diameter - Inches 0.82 End Type 1 Tangential End Type 2 Pigtail Free Height - Inches 13.61 ID - Inches 3.67 Installation Height - Inches 10.00 Load - lbs 3841.00 Spring Rate - lbs per inch 1060.00 Spring Type Constant Rate Alternate/OEM Part Number(s): 328098, 328099, 328100 |
1 coil on stock springs is a 2" drop. You cut a tad to much lol
Matt |
How much drop is 1 coil off drop springs? 2" as well?
Probably 1", drop springs have more coils with a higher spring rate.
Matt |
Thanks everyone. I just bought the Moog 6454 springs from SummitRacing. Couldn't beat the price, $8.97 a pair plus shipping. Must be a mistake, but I bought them before they see it. The cheapest Moog 6452 springs I found are $69. One-ton springs it is.
Holy OOPS Batman ... I ordered a set too and I don't even need them right now... I though you had a typo in your post till I checked out the site...
#13 |
In for a set just because........thanks for the heads up.............
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
#14 |
Bought a set myself! $15 shipped is a steal! Glad I looked into this!
#15 |
Great deal! I just ordered a set for $14.92 shipped! Im in the process of dropping my truck and was gonna cut the old rusty stockers..
#16 |
all you people ordering them.. now they show ship today, but when you check out, they say back ordered with an estimated ship date of Nov. 5
Project Roxy... Shes Bad, Low, and Blown... http://67-72chevytrucks.com/vboard/s...d.php?t=673333 Last edited by Domer; 10-12-2015 at 12:33 PM. |
#17 |
They had 10 pairs available when I ordered mine.
#18 |
There is a easier and cheaper fix for this. I've been running this set up for a while now. AFCO makes a coil spring spacer/adjuster for the dirt track application. This also works very well when your truck doesn't sit level across the front
#19 |
driving is in my blood
^ Thats a good find, something to remember for down the road when needed.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
#20 | |
#21 |
damn they are still there
http://www.summitracing.com/int/parts/mog-6454 I thought about buying but I would prefer a drop spring - damn good price though
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ |
#22 |
I could not resist!
I need to change one spring, front end is sitting 3/4" lower on the passenger side, so I guess I will change two at that price!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#23 |
When you receive them would you check the static height (length), Thanks
#24 |
Mine were delivered today.
#25 |
just got some.... don't really need them but you never know when you will, and at 14.92 you can't go wrong.
