How much for materials?
I have a buddy who will paint my truck for the cost of the materials. How much would it cost in materials to paint my truck(Gm torch red)
$100-$500
Watch out for your cornhole !
![]() Join Date: Jun 2003
Last one I did cost 800 for paint supplies. All PPG base/clear urethane stuff.
![]() Join Date: Aug 2001
![]() ![]() (OOPS.... I JUST REALIZED YOU WANTED TO GO WITH RED, WITCH IS THE MOST EXPENSIVE COLOR.... YOU BETTER ADD ANOTHER $75)
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 09-13-2003 at 11:26 PM. |
price depends on the TYPE of paint as well as the BRAND.
Remember, especially with paint & paint work, you get what you pay for. |
Car Knocker
Like Shane said, depends on what type and brand of paint. 100 dollars will buy alot of rattle cans. Some top end paints will run you over a 1000 dollars a gallon. The question is, how long do you want it to last?
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
68cst_ss490
paint is expensive if you want the good stuff
my yellow paint cost me around 400 a gallon
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
![]() ![]() USING TOP QUALITY MATERIALS DOESN'T GARENTEE YOU A GOOD PAINTJOB. ALOT DEPENDS ON PREPERATION & APPLICATION ALSO. ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
How much paint/materials would it take to paint a truck so i can strat pricing things.Thanks.
Dude, you need to talk to your painter....
Single stage paint will use a lot more paint, like 1-2 gallons probably. Base/Clear could use as little as 1-2 quarts of paint. Then clear on top of that. Also, you will need reducers, catalyst, sealers, primer, tack rags, paper, tape, pre-kleen wax and grease remover, color sanding paper, buffing and polishing compounds, etc.... Your painter will tell you which paint system he uses (urethane, acrylic enamel, single stage or two stage). Also, different colors cost different prices. Your painter will likely be very particular about what brand he uses too. I know I am. Also, your painter will likely be able to buy the products through his shop for a lot cheaper than you can.
1969 Custom 30 wrecker
I painted my own truck (also a short stepside) and I used Acrylic Enamel. It's cheap, and perfect for me as im not a professional painter. (although I've done about 12 by now) I drive my truck all year long and touch ups/resprays are a fact of life so I wouldn't want expensive paint.
My blue cost me under $75 for a gallon. You could spray your whole truck with one to one and a half gallons. (I think I used 1 gallon and one quart for mine but that was inside and out as well as the engine compartment) When red is involved, it gets alot more expensive. Could almost double the price I believe. Remember too, a paint job is only as good as the body work under it. Paint will only highlight bad body work and repairs not done correctly will pop out eventually. I'd be afraid to drive my truck if the paint alone cost $1,000. LOL ![]() ![]()
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
It's true about red - the Guards red I used on my truck was just about $350 a gallon - Chroma - Base II - (base coat). There are also different grades of clear - I used the mid range stuff which was about $100 a gallon if I remember correctly. By the time it was done, materials ended up being about $1200... This was about 10 years ago.
Good point about preparation - spend the extra $$$$ so your painter will spend the necessary time doing the prep work and not take short cuts.
Rudy Fierros '95 Honda VFR750F Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it! |
#13 |
Same story, did a 69 Camaro for a buddy of mine, "Viper Red". This was about 8 years ago, and $1,300 worth of materials (Dupont Centari). If your on a budget, red isn't going to keep you there.
#14 |
Thanks guys for all the help. I dont know if i can afford red so anybody have any suggestions for other colors. I dont feel like redoing the inside so it would have to look good with red. Thanks
Eric |
#15 |
Black and red look awsome together, and it just happens that black is the cheapest color.
#16 |
![]() OR WHITE...... IT TENDS TO COVER ALL KINDS OF FLAWS ![]() ![]()
