Rear End Swap
My '76 C10 has a 12-bolt non-posi rear end Have not had it apart to check tolerances, but it has seen better days. This truck has wide performance radials on all four corners, but still gets terrible traction when unloaded. It loses traction very easily on wet roads, and the rear brakes lock up very easily. I just drive it normally, no drag racing for me. The left brake has a history of auto-tightening on its own, and the drums are at their limits (probably why the brakes tighten up). In contrast, my '89 S10 longbed with ABS and the optional sport suspension handles and stops awesome for a truck.
Am considering replacing the entire rear axle unit with a better one that has positraction and better brakes, if there is such a thing. Is there a later range of years that you can recommend getting a donor rear end from that I can do a direct swap into my C10? |
Collector of Projects
Re: Rear End Swap
I was just researching a 1994-1996 Impala SS /9c1 Caprice rear axle swap. 5x5 bolt pattern with factory rear disc brakes and built in e-brake (unlike most brakec onversion kits.) I cant seem to find the axle width from wheel mounting surface (WMS) to wheel mounting surface for the truck or the Impala. You would need to add the correct spring perch and an adapter for the brake line because I think they were metric fittings by then.
#3 | |
Re: Rear End Swap
Re: Rear End Swap
You can add an adjustable proportioning valve to turn down the rear bias so the front locks up before the rear would. The Impala SS (or 9c1 cop car Caprice) was a heavy car meant for sever duty. I wouldn't have a problem running that rear with a nice posi in a 1/2 ton truck. I just picked up a 78 2wd Blazer and was thinking of going this route.
#5 | |
Re: Rear End Swap
FYI, an area search of auto parts on CL for caprice, impala, roadmaster or 9c1 found a pair of front brake assemblies and a few wheels, that's all. All the wrecking yards around here are a joke, never have anything I'm looking for. |
Diggin The SquareLife
Re: Rear End Swap
impala ss rear end is narrower than the c10 rear end an the caprice rear end is even narrower than the impala...I don't see why you would want to keep drum brakes when disc are better....impala/caprice rear ends come with 3:42/3:73 gears posi unit an of course disc brakes.....only need to add leaf spring mounts an a u joint
Re: Rear End Swap
Re: Rear End Swap
Bolt in axle you have zero options on that,Some others will fit but you gotta weld on new spring perches and shock mounts.I would have a lsd installed in your 12 bolt and do a disc brake swap on the rear.Maybe throw on a set of traction bars if needed.
Re: Rear End Swap
Thanks for the feedback.
This truck sat from the end of last summer until last month. Since I started driving it again, I've had a "funny feeling" about the diff. Yesterday, I found that the diff vent hose has a hole worn through it from the exhaust pipe. I suspect this has contributed to corrosion and excessive wear in the diff. I already know it needs new brake drums, and suspect the diff and possibly the wheel bearings are pretty worn out. Figured swapping in a less worn out rear axle assembly would be easier than fixing all that stuff. I would be happy with a fully compatible rear end with decent set of drum brakes that don't grab or tighten on their own. My S10 has the heavy duty load and towing options, but only has a light-duty hitch, so the C10 gets all the towing jobs. |
driving is in my blood
Re: Rear End Swap
You can either swap in another 73-80 12 bolt or a 81-87 10 bolt, otherwise nothing is a direct fit. They all have drum brakes that will work just fine when serviced correctly with good parts. The oem posi units will be decades old at this point, you might want to consider adding a posi to your current axle and rebuilding the brakes.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
#11 | |
Re: Rear End Swap
Re: Rear End Swap
a place called summit racing....
#13 |
Re: Rear End Swap
Oh, OK. Hadn't thought of summit. They have two units by Auburn Gear, $429 (3.73 or higher gear ratio) or $475 (2.76-3.42 gear ratio). Not sure what ratio I have.
#14 |
Re: Rear End Swap
My opinion, If the axle is that old, I'd change the ring and pinion too. So decide what kind of ratio do you want/need, and get the locker for that.
Paul |
#15 |
Re: Rear End Swap
As for the proportioning valve with 4 wheel disc brakes. We just finished up my buddies 72 with 4 wheel wilwood 14" rotors and 6/4 piston calipers. once adjusted, that thing stops flat with hardly no nose dive, oh and damn quick..
Project Roxy... Shes Bad, Low, and Blown... http://67-72chevytrucks.com/vboard/s...d.php?t=673333 |
#16 |
Re: Rear End Swap
It depends if you want to stay with a stock ratio or want something a little better?If im replacing a diff i would replace the gears also since they are old enough and why do it twice.What trans do you have and do you plan to keep it or upgrade later on?
#17 |
Re: Rear End Swap
Well this answers one question and I believe I found the info on an Impala SS forum stating the SS rear is 63" and the 9c1 rear is 61.5" wide. Wagon rears are wider but no disc brakes.
