Old 10-11-2015, 11:47 PM   #1
88Stanger
88Stanger's Avatar
how to add PVC and Oil filler cap to new valve covers
Ok, so i bought a nice set of brand new aluminum valve covers that do not have provisions for a PVC or an oil filler cap.
1.) So, if i am not mistaken, i can get a PVC valve and grommet setup, drill a hole in the valve covers for the grommet and PVC. Does it matter what side the PVC goes to?
2.) I am not sure what i can do for an oil filler cap. from what i can tell there are no provisions on the underside of the valve cover for this. So i am looking for some ideas here. One is to find a bung that can be welded to the valve cover that i could then put a screw in plug. Not the best, but with a funnel it could work, the only bad thing is that i do not have a heliarc or know someone who does. So any other ideas is appreciated.
Thanks for the help.
attached is a pic of the covers
88Stanger is offline   Reply With Quote
Old 10-12-2015, 12:47 AM   #2
88Stanger
88Stanger's Avatar
Re: how to add PVC and Oil filler cap to new valve covers
if you can see the photo, the are no holes in the valve covers now.
Old 10-12-2015, 08:35 AM   #3
chiefcfd
chiefcfd's Avatar
There are several different caps like this. Just drill a hole and install a grommet. I would use something on both sides. Use as the oil fill also.
http://www.summitracing.com/parts/mrg-2054/overview/
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 10-12-2015, 01:30 PM   #4
jocko
jocko's Avatar
Google on this site an article by markeb01 about pvc install. I don't have I handy. Good thorough description of what and how.
Old 10-12-2015, 01:44 PM   #5
trac209
I assume the valve covers don't have an oil baffle inside though? Sometimes that can lead to a bit of oil getting into the pcv valve.
trac209 is offline   Reply With Quote
Old 10-12-2015, 02:17 PM   #6
graymond1967
graymond1967's Avatar
Make sure the grommets you get are baffled. Otherwise you will be sucking up oil, and that can be messy.
I have my pvc on the passenger rear and the oil filler/vent on the driver front. Works the best with plumbing from the carb etc.
cheers.
ray
1967 Chev C10, in the family since 1967, iron head 502, turbo 350, white with red, unrestored.
1970 Acadian SS350, 350 with muncie 4 speed, 12 bolt, best time 13.414 @ 103.72
graymond1967 is offline   Reply With Quote
Old 10-12-2015, 02:53 PM   #7
cleszkie
cleszkie's Avatar
x 10 on using a baffle under the PCV valve. You would be surprised at how much oil can be sucked into the PCV valve and burned in the engine. Ask me how I know
I don't have an oil filler on my custom aluminum valve covers. I just pull the PCV valve and add oil with a funnel.
cleszkie is offline   Reply With Quote
Old 10-12-2015, 03:38 PM   #8
geezer#99
geezer#99's Avatar
Don't you save anything Jocko!! LOL!!
http://67-72chevytrucks.com/vboard/s...d.php?t=366830
geezer#99 is online now   Reply With Quote
Old 10-12-2015, 03:57 PM   #9
jocko
jocko's Avatar
Luckily I have a good memory! Actually, I'm quite the hoarder, just don't keep anything on my cell... Thumbs too big. Had to type this reply about 5 times forbittoevenreadcirreclty.
Old 10-12-2015, 05:42 PM   #10
vidman
vidman's Avatar
This is how i did my Brodix covers. only have a pic of one cover but 1 has a welded bung for the filler and a gromet for the pcv and the other cover has a gromet for the breather. used some 22 gauge sheet aluminum for the baffels
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 10-26-2015, 01:20 AM   #11
88Stanger
88Stanger's Avatar
thanks for the ideas!!
Old 12-27-2015, 08:27 AM   #12
dazza
dazza's Avatar
Is that all there is to your baffle? Just the piece of aluminum raised with the sides open? I'm just curious because I may go that route with my covers.
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 12-27-2015, 09:33 AM   #13
snipescastle2
snipescastle2's Avatar
Talking Re: how to add PVC and Oil filler cap to new valve covers
Safety Wire, now that's Insurance!!! great Idea!
Ben
snipescastle2 is offline   Reply With Quote
