10-12-2015, 12:00 AM | #1 |
71-72 Whole front end swap on a 65
So if I get this right..i can take a 71-72 whole front end and swap out my 65s?
Only need to drill out some holes? Looking at an entire 71 or 72 rolling frame with disc front and 3.08 rear 5 lug |
10-12-2015, 02:47 AM | #2 |
Re: 71-72 Whole front end swap on a 65
This should help you http://67-72chevytrucks.com/vboard/s...d.php?t=364621
10-12-2015, 01:25 PM | #3 |
I'm looking at different cheap a$$ trucks to get the parts from
It seems that 73&up works better or more straightforward than 71-72 73 up to what year? Will 90s trucks front/rear end work on a 65? |
10-13-2015, 02:03 AM | #4 |
73-87 1/2 ton truck or the suburban was the same body tell 91 but make sure its a 1/2 ton 2wd.The easy way to tell a 1/2 ton is the 5 lug anything else is 6 or 8 lug.The rear ends im not sure on the widths but it would take welding on new spring perches if its a truck arm truck you have,If its leaf springs would be new spring perches and shock tabs.The other way is http://www.earlyclassic.com/ sells 5 lug swap axles and drums for it tho.Its not the cheapest option but a bolt on one.
10-14-2015, 05:45 PM | #5 |
1965 Chevy C10, 2005 4.8L/4l60
I have front and rear in my 65 from a 71/72. I went with drop spindles also. Cheaper yes for 73 up, also a little heavier duty as well, be sure to use the hd brakes.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
