Old 10-12-2015, 01:38 PM   #1
jimmystepper
Trailing Arms
Hello, 1 more question, my trailing arms have a bump or raised area next to where the spring cups mount. Is this normal? All the aftermarket arms and also repair kits do not appear to have this raised area. I thought that might be to support the other edge of the spring, but now I'm confused. Anyone have any thoughts? Thanks in advance for your response.
1966 chev. short stepside
jimmystepper is offline   Reply With Quote
Old 10-12-2015, 10:38 PM   #2
racecougar
racecougar's Avatar
Re: Trailing Arms
Have a photo of the area you're referring to?
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 10-12-2015, 11:14 PM   #3
jimmystepper
Re: Trailing Arms
I will get one tomorrow when my son comes over. Thank you, Jimmy
Old 10-13-2015, 01:31 AM   #4
Captainfab
60-66 Nut
Re: Trailing Arms
I have not seen any factory truck trailing arms with any sort of bump or raised area near the spring or anywhere on the top surface. If this is to the rear of the spring, your trailing arms may be rusted and weak and could be bending and buckling.
Old 10-13-2015, 11:43 AM   #5
jimmystepper
Re: Trailing Arms
Racecougar and Captain Fab thanks for your replies. I have a bump on each side inline with the coil cup mtg. screw. It is on both outboard sides of the arms. I also traced the bump on the poster board. Captain Fab I think you are right about the arm buckling. Here goes more $$$ into the money pit. Thanks, Jimmy
Old 10-13-2015, 05:31 PM   #6
racecougar
racecougar's Avatar
Re: Trailing Arms
That looks like it could have been created by a PO. That is right where the e-brake cable contacts the edge of the arm...maybe someone thought that the cable sheath would rub against the edge of the arm and cause a problem (it won't)?
The bottom of that arm looks pretty well beat, too.
Old 10-14-2015, 12:32 AM   #7
Captainfab
60-66 Nut
Re: Trailing Arms
Yes those trailing arms have been beat on pretty good. They are also starting to separate on both sides of the spring bolt. If they are not rusted thru, they can be saved. You will need to remove them from the truck, clean them up good, squeeze them back together and stitch weld the halves together.
Old 10-14-2015, 10:57 AM   #8
jimmystepper
Re: Trailing Arms
CaptainFab, Thanks for the reply, Im gonna give it a shot , Jimmy
