Old 10-12-2015, 01:46 PM   #1
J1MMY
'63 12 bolt rear
Will it physically take a 2:73 diff and if so are there any outlets that can supply this? Stock gearing is killing me, even on 28.5" tyres!
'63 C10 Longbox fleetside
'94 C1500 Sierra ex-USAF beater
J1MMY is offline   Reply With Quote
Old 10-12-2015, 02:08 PM   #2
vince1
Re: '63 12 bolt rear
My understanding is no, unless the carrier is also changed. Something about series 3 or 4.
I had a 64 3.73 in my 66 for a while. Took it out and put in a 3.07 from a 71, which still has the six studs but is 1 1/2 wider.
You might get better results with putting in an overdrive transmission.
vince1 is offline   Reply With Quote
Old 10-12-2015, 02:29 PM   #3
The1960APE
The1960APE's Avatar
I don't have an answer but google Randy's Ring gear, I always use them for rear end parts, great products at good prices! And they are VERY knowledgeable
The1960APE is offline   Reply With Quote
Old 10-12-2015, 04:43 PM   #4
J1MMY
I don't want to go with an O/D trans as the SM420 is in fine working order and id rather not cut holes in the hump.
How have you found the 3.07? What trans are you running? I took the cover off
The axle on my '79 donor this evening and it has a 3.07 in it. I am aware of the whole series thing with the 12 bolts but don't understand it.
Old 10-12-2015, 04:57 PM   #5
Brad54
Brad54's Avatar
Basically, the "series" thing works like this:
The thickness of the ring gear is different, depending on what the gear ratio is. It's in the manufacturing process.
The "case break" (series) are specific to those different ring gear thicknesses. If you put the wrong ring gear on a case, it'll either be too far or too close to the pinion gear.
I don't know what the actual "case breaks" are on the 12-bolt... On the Dana 44, it's 3.90-up, and 3.73 down (and there might be a third case break farther down).
Oddly, Mopar 8 3/4 and Ford 9-inch drop-out rear ends don't have case-breaks--they just make the ring gear itself thicker or thinner so they all ride on the same differential case.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 10-12-2015, 05:21 PM   #6
vince1
The 3.07 is sort of OK I guess as far as rolling down the highway goes. I have the 4sp manual and hate changing gears so I see a 700R4 in the future. Might have to go back to the 3.73 though if I do that.
Old 10-12-2015, 07:35 PM   #7
Genuine GM
Genuine GM's Avatar
The more teeth on the ring gear, the thicker it is, so the carrier has a thinner flange. 2.56-2.73 is Series 2. 3.08-3.73 is Series 3, and 3.90 up is Series 4.
If you don't need posi you can find plentiful series 2 carriers with 2.73 gears in late 70's square bodies. Sometime in the early eighties they dropped the 12 bolt, '81 maybe?
If you want posi you'll be looking at Auburn or Eaton aftermarket.
Don't let my username fool you, I have become brand blind. Cool is cool, period.
1965 C-10 - "Whipping Post"
1958 Biscayne - "Ruby"
1961 IH Scout 80 - "Gaucho" (My wife's new project)
1938 Chevy - unstarted project.
Genuine GM is offline   Reply With Quote
Old 10-13-2015, 01:14 AM   #8
Captainfab
60-66 Nut
On the truck 12 bolt if you wan to switch to a gear higher than 3.73, which is what you likely have, you will have to change the carrier. Since the '63 & '64 12 bolts have 17 spline axles, you will have to either install your 17 spline spider gears into the new carrier, or switch to 30 spline axles. In my opinion the 3.42 gear is a good all around gear, but your rpm's will still be a little high for highway driving. If you go with a 3.07 gear or higher, you will likely have to use 1st gear for everyday driving. This is of course dependent on what engine you have.
Those are the carrier splits for the car 12 bolt. The truck 12 bolt is 2.56-2.73 is 2 series 2.76-3.42 is 3 series and 3.73 and lower is 4 series.
Old 10-13-2015, 06:24 AM   #9
BigDan3131
BigDan3131's Avatar
The whole reason for those gears is because of that tiny little engine that doesn't make any power and putting 2.73 gears in it is going to kill any acceleration you have now. Since you don't want to switch trans buy 33" tall tires instead.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 10-13-2015, 09:00 AM   #10
vince1
Yes, IMO 273 is too high.
With 3.07 I still don't get it into 4th very much when driving in the city. A lot of it is done in third. 3.73 would be better for on the farm or in the city at 30 - 40 MPH. On the highway though the 3.07 lets you cruise nicely at 60 - 65 MPH. And it will go still go faster if you want it to.
Old 10-13-2015, 11:30 AM   #11
Evoracer
I have 3.42's with a granny 4spd, 400sbc. It's ok around town, still not enough gear for freeway speeds, imo. 3.73's were awesome around town. 3.07 in my future.
Evoracer is offline   Reply With Quote
Old 10-14-2015, 10:04 AM   #12
Genuine GM
Genuine GM's Avatar
Yep, got those mixed up in my mind.
Old 10-14-2015, 04:37 PM   #13
blackbart63mule
blackbart63mule's Avatar
BACKING PLATE WELDED TO AXLE TUBE. While on the subject of 63 12 bolts- I have a 63 1/2 ton panel, built in December 62, the backing plates are attached/WELDED to the AXLE tubes from the factory. Anybody know of a disc brake set-up that adapts to this? After hearing about the 17 spline versus 31 spline, and having a better choice of custom wheels, I may go with 5 lug aftermarket axles. I've even thought of cutting the attached DRUM backing plate down and making adapters to fit a disc brake setup, I would definitely need/keep the emergency brake and original handle as is in the cab. I've never heard of any aftermarket kit or cure for this, or have been able to find mention of it in this in forum. I've also thought I may have to replace the whole axle assembly with new/used unit because the current one is an open, no posi one. I have'nt figured cost into this yet, either. Any thoughts, ideas, comments is greatly appreciated. Dog..........over and out
blackbart63mule is offline   Reply With Quote
Old 10-15-2015, 01:21 AM   #14
Captainfab
60-66 Nut
The only way to convert a '63 12 bolt to disc brakes is to cut the original backing plate off and weld a caliper mount onto the axle tube.
Old 10-16-2015, 02:09 AM   #15
blackbart63mule
Thanks for the info Captainfab, the D52 setup looks pretty good, I've been contemplating about this since my first 63 panel truck over 20 years ago. Hate to throw a wrench in the works, but do you think this might somehow work with a truck 12 bolt c-clip eliminator factored in there since a new flange has to be welded on to the axle tube anyway? Looks like it might come down to the thickness of the spacer block versus eliminator block? Thanks for sharing your input and expertise. I realize we may have to have the dimensions for the c-clip block to figure this out.
Dog.
Old 10-17-2015, 01:14 AM   #16
Captainfab
60-66 Nut
It's been many years since I have dealt with a C-clip eliminator, but if my memory is correct, I don't think they will work with any of my rear disc brackets. As for installing either on a '63 12 bolt, a flange would have to be welded onto the axle tubes that is perfectly parallel to the axle flange. That is not something easily accomplished by the average guy/gal. Of course in doing just that, the added thickness of the rear disc base plate, could be compensated for.
