Old 09-13-2003, 10:10 PM   #1
JoetheMobster
Listening since '86
JoetheMobster's Avatar
Question for GMC guys + headlights
I was curious if anyone has changed the 4 headlight setup from 2high/2low beam to 4 high/low beams?? Is it possible with stock wiring, and not frying any wiring/switches etc.?
If you read this Zurbo - thanks for making me curious!!
2007 Saturn Aura - hey it WAS a GM product
JoetheMobster is offline   Reply With Quote
Old 09-13-2003, 11:52 PM   #2
JoetheMobster
Listening since '86
Nobody huh
Old 09-14-2003, 12:01 AM   #3
krue
Designated A-hole!
krue's Avatar
Man my lights are wicked bright with just two of them bright!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 09-14-2003, 12:09 AM   #4
Phillip Johnson
Phillip Johnson's Avatar
Ive changed a 4 headlight GMC to a 2 headlight CHEVY! So much nicer to look at, in my opinion!
Phillip Johnson is offline   Reply With Quote
Old 09-14-2003, 12:32 AM   #5
Maximum Overdrive
December 21, 2012
I havent done it on mine. It seems it would be easy enough to do though.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 09-14-2003, 01:38 AM   #6
dtlilly
dtlilly's Avatar
I was thinking of trying to convert to a 2 low 4 high system, but I guess it's more of an arm chair idea
dtlilly is offline   Reply With Quote
Old 09-14-2003, 08:18 AM   #7
jay6891
Car Knocker
jay6891's Avatar
I don't think that you could go to a 4 low/4high. Unless I'm thinking wrong. with all 4 on it would always be on bright. Seeing how its not a brighter bulb for brights, its the angle that they are sitting in the bezel and where they are aimed.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 09-14-2003, 09:54 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I am sure it would be pretty easy to do and be legal still. They make a kit for 89 and up chevy's that let all four light's be on..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-14-2003, 10:45 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you want all 4 headlights to be on while on low beam, then it would not be legal.It could be done pretty easily though.
If you want brighter headlights, first step would be cleaning your grounds real good. I did this on Jewels's truck and it made a huge differance. Some new hallogen headlamps would be a good next step, as would be double checking your head light aim.
I have done all that, and my head lamps are qute bright. However, I want them to be new car bright, so I am going to wire them up with a couple relays.
It is pretty easy to do, here is a link I have found that lays it all out for you. http://www.classictruckshop.com/club...ead/lights.htm
This really does make the differance of night and day. As your truck is now, you may be getting as little as 10 - 11 volts to your headlams. With the relay, you'll get more like 13 to 13.5.
Old 09-14-2003, 02:16 PM   #10
Green72GMC
Green72GMC's Avatar
All 4 of yours aren't already on when you have high beams on?
1972 GMC SWB, 305 powered
1980 diesel VW pickup, Needs a Heart Transplant
1997 Toyota Taco
The Second Amendment is in place incase they ignore the
others.
Green72GMC is offline   Reply With Quote
Old 09-14-2003, 02:21 PM   #11
dtlilly
dtlilly's Avatar
Unfortunately not. They were wired by the perverbial dope smoking old man (no not me )
Low beam = two outer lights
High beam = two inner lights
Old 09-14-2003, 02:23 PM   #12
Green72GMC
Green72GMC's Avatar
Oh, because all 4 of mine are on when I have High beams on. and 2 when its on low beams.
1997 Toyota Taco
others.
Old 09-14-2003, 02:31 PM   #13
dtlilly
dtlilly's Avatar
My truck wiring is a fire waiting to happen. With all the old wires, and the new wires spliced together, I'm lucky anything works.
I have a Haywire wire kit, just waiting for the time/money to begin the resto. Sounds like I'll need to pull some connectors off a junk truck to get the lights working right.
Old 09-14-2003, 04:51 PM   #14
Figment412
I have thought about using one set for high low beams and putting some high performance lights in for off-roading.
Save your money and do it right the first time.
1968 GMC short bed
1972 Cab
74 SB Chevy running gear
Figment412 is offline   Reply With Quote
Old 09-14-2003, 05:34 PM   #15
dtlilly
dtlilly's Avatar
I read on the board awhile back about using aircraft landing gear lights for the inside lights. That would look pritty neat too
Old 09-14-2003, 06:40 PM   #16
Longhorn Man
Actually, you may want to look into your local laws on that one too. I know here that is a no-no.
Old 09-14-2003, 06:46 PM   #17
jewels.
jewels.'s Avatar
Longhorn is correct! If your problem is dim headlights, don't rewire them to four headlights, just fix the headlights you have. Try re-grounding them. Then, change out the lamps with some new halogens. We did this to my truck (thanks longhorn!), and boy, I can see miles now!
good luck!
jewels.
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
Old 09-16-2003, 12:48 AM   #18
GMC Jim
GMC Jim's Avatar
The GMC 4 headlite system uses the PAR 46 bulb ( 5.7" diameter). Original lamps were outer lamps; #4000 hi/lo beam @ 37.5/60.0 watts. Inner lamps were #4001 hi beam @ 37.5 watts.
This combo produced :- Hi beam ( 4 lites on) total wattage 150 ( 37.5 X 4 = 150). Lo Beam ( outer lites on) total wattage 120. (60 X 2= 120)
The charts list halogen lamps as replacements. Outer lamps ( lo-beam) #H5006 35.0/35.0 watts. Inner lamps (hi-beam) #H5001 50.0 watts. This will give a total wattage for hi beams of 170 and a total wattage for lo-beams of 70. This lo beam wattage is actually a downgrade compared to the original configuration !!! ( the original #4001 is no longer available)
I configured my headlite system using # 4000 (37.5/60.0 watts) for the outer lites. The inner lites are #H5001 (50.0 watts). This combination give a total of 175 watts for hi-beam and 120 watts for lo beam; an improvement over the original.
Also, installed relays and 12 gauge wiring to the headlites which ; as Longhorn Man states, supplies about 13.4 volts to the lites.. Have been quite pleased with this conversion......Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
