Old 10-12-2015, 09:24 PM   #1
62stepside longbox
62stepside longbox's Avatar
What needed to swap to 292
I currently have a 261 (same as 235) in my truck with 4spd. But I have been offered a 292 with power steering, intake and headers from a friend for $400. What will need to be changed to go to a 292? Bell housing? Motor mounts? Anything else? Thanks.
Nik
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 10-12-2015, 10:25 PM   #2
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: What needed to swap to 292
Bell housing....clutch and pressure plate....You'll need mounts and perches for a 292....That has a manual clutch right?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-12-2015, 11:08 PM   #3
padresag
there are several ways to do it. if you can find a 60-62 283 bellhousing will simplify your clutch problems as it has the passenger side access for the hydr. clutch the 60-62 housing will fit a chev engs 63 and up for many years.
ron
padresag is offline   Reply With Quote
Old 10-12-2015, 11:22 PM   #4
scuderia
scuderia's Avatar
Nik
I need friends like that : )
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 10-13-2015, 01:01 AM   #5
62stepside longbox
It's a hydraulic clutch
Old 10-13-2015, 01:33 AM   #6
62stepside longbox
ron
So will only the 60-62 283 bell housing work? Or will any small block bell housing work? And will any small block motor mounts bolt right in or will they need modification? Any help is appreciated as I am very lost right now.
Nik
Old 10-13-2015, 01:56 AM   #7
padresag
Nik
if you can find a 60-62 283 bellhousing will simplify your clutch problems as it has the passenger side access for the hydr. clutch. if you do not understand your truck should have a passenger side mounted clutch now. these are the only years that was installed. it saves you from fab a drivers side clutch setup.
ron
Old 10-14-2015, 12:21 AM   #8
padresag
this is basically the same except that the passenger side perch is set forward for the 292 eng
http://67-72chevytrucks.com/vboard/s...d.php?t=369663
forgot the link
ron
