Old 09-13-2003, 10:11 PM   #1
casey
casey's Avatar
power steering cooler
anyone have a power steering cooler, I seen one at pick-a-part the other day, thought it looked pretty cool so I bought it, does the power steering fluid get that hot? I was also wondering about engine oil filter options, I've seen ones that look twice as long as the standard ones any thought on this. another cool thing I seen the other day was a guy put a oil filter adaptor on his transmission lines running to the trans cooler, what do you guys and gals think of this stuff?????
casey is offline   Reply With Quote
Old 09-13-2003, 10:57 PM   #2
Dusti
Not Dusti,just Bob
Dusti's Avatar
I have never seen a power steering cooler,got any pics?
I bigger oil filter should help clean the oil better and give you a little more oil capacity.
Bob W
72 cheyenne super 1/2ton
89 camaro
Dusti is offline   Reply With Quote
Old 09-13-2003, 11:51 PM   #3
casey
casey's Avatar
haven't got a pic but its a 10" piece of tubbing with fins on it
Old 09-14-2003, 12:00 AM   #4
darksaga
darksaga's Avatar
im useing one right now but its a small trans cooler put it on the return line
1968 gmc 3/4 4x4 longbed. built 469 700r4 (needs a th400 REAL SOON!), 14bolt ff rear 73 3/4 dana 44
1970 chevelle all wheel disc, tubular rear control arms tall spindle swap up front matching #'s 350 work in Progress
darksaga is offline   Reply With Quote
Old 09-14-2003, 12:30 AM   #5
casey
casey's Avatar
why did you put it on, was your power steering pump failing from over heating??
Old 09-14-2003, 08:54 AM   #6
cdowns
cdowns's Avatar
alot of ford products came with ps coolers in the 70's aand 80's
Old 09-14-2003, 09:25 AM   #7
darksaga
darksaga's Avatar
yes about my 3rd sharp turn in a row I would loose assist so I replaced the pump and added a cooler tires are 33x12.5
