Chevy 12 Bolt Rear End Cover
Hi,
I would like to change the Rear End Cover from my 66 Chevy C10. I have the original Cover. I have the original Panheadbar and the Brake Lines who are mountet on the Cover. I would like to buy the Cover from TA Performance TA_1811 A with the Low Profile. Have anybody this Cover ? I there a Problem with the Brakeline and the Panheadbar ? Thank you verry verry much. Greetings from Germany Nils |
![]() Join Date: Jun 2006
Re: Chevy 12 Bolt Rear End Cover
I have one on my 10 bolt, its best for strength to get the stud kit too. Panhead Bar? you mean the rear sway bar? the brake lines run above it and the bar should be far away from it.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
Moderator
![]() ![]() Join Date: Aug 2011
Here is some info you might wish to consider: http://67-72chevytrucks.com/vboard/s...d.php?t=684268
I like that rear end cover too, but until I see someone else use it with success with our panhard bar it may have to wait (for me anyway).
Hi,
Thank you verry much for the fast answers. Greetings from Germany Nils ![]() |
![]() Join Date: Oct 2013
You could e- mail Mike at TA Performance, to see if they have any experience in your application.
I may see him tomorrow at the Buick GS Nationals and will ask him, for you. Also, will take a photo of my DTS aftermarket chromemoly 12 bolt, with cover installed, may help you, better see what it will look like installed. This application does not have a panhard bar. Les |
#6 | |
Thank you verry much that you will ask Mike from TA. Greetings Nils |
Info on the TA 12 bolt cover, this one does not have TA on it , but is made by TA , and is same.
Took me longer, to get information back to you, out of town. If any interest, DTS makes this 12 bolt rear end and is the one Mark Williams sells under their name, super strong. Les Last edited by aotte1; 10-21-2015 at 12:55 AM. |
It shows cover extends back from 12 bolt about 4 inches, e. g. Cover is 4 inches thick.
Hope this helps. Les |
Another photo
One more
Let me know if you need other measurements.
Les |
If you are wondering, what the photos were taken on. It is a 1970 Buick GS, C/SA NHRA Stocker.
#13 |
Good morning Les,
Thank you verry much for the information and the pictures. This will help me a lot. If i have any Question i will ask. Thanks a lot again. Greetings from Germany Nils |
#14 |
Nils,
I run an LPW braced cover on the 12-bolt in my '66. It's the Ultimate-series cover. It clears the factory panhard bar on mine without any trouble. My truck is lowered 4" in the rear, also, which puts the bar closer to the cover, but still no clearance issues. I'm not 100% sure, but I would guess that the T/A cover and the LPW cover are pretty close in thickness.
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
#15 | |
thank you verry much for your answer. I take a look on the LPW Cover 201-12T. It looks like the TA/Cover. A nice different i think is that the LPW Cover have a magnetic drain plug. I think that the quality of the Moser, T/A and LPW is the same. What do you think ? Have a nice weekend. Nils ![]() |
#16 |
Nils,
I would agree with you on that. I'd say that any of those covers would be good quality parts. I bought the LPW cover with the intent of installing the braces on the axle tubes and attaching them to the cover. If you don't plan on adding those axle tube braces, then any of those covers would work well for you. You have a great weekend, also!
