10-13-2015, 01:43 PM | #1 |
C/10 junkie
WTB 3 on the tree shift lever
Mine broke at the end where it connects to the column. Let me know what you have shipped to 95209. Thank you!!
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
10-13-2015, 03:13 PM | #2 |
Re: WTB 3 on the tree shift lever
I have one. I think the chrome is not that great on it. Let me know if interested and I will dig it out and get some pics.
Thanks, Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
10-13-2015, 03:17 PM | #3 |
C/10 junkie
As long as it isn't broken anywhere then I'll take it. Not worried about the ascetics lol it just needs to work. Thank you
10-13-2015, 03:23 PM | #4 |
Always on the hunt...
You may want to add a picture of the broken lever that is needing replaced or state the original year of steering column that it was removed from, there were a few different styles of the 3 spd. column shift levers used between 67-72. Once you confirm which one is needed, I may also have the lever available. Mel
10-13-2015, 03:37 PM | #5 | |
C/10 junkie
10-13-2015, 04:00 PM | #6 |
I think the earlier columns had a smaller hole for the lever, I ran into that when I had to replace mine one time. I got one out of a 72 with an automatic and I had to grind on it
a little to get it to fit into the hole on the column. The little ball on the end was the same size though.
10-13-2015, 04:04 PM | #7 | |
C/10 junkie
10-13-2015, 04:15 PM | #8 |
C/10 junkie
one more with a measurement
10-13-2015, 04:21 PM | #9 |
That's what happened to mine. I was able to weld it back on but it ended up breaking off again.
10-13-2015, 06:30 PM | #10 |
Here is a pic. Don't know if the length is correct. This one seems short to me. Let me know what you think. $20 shipped if it will work for you.
10-13-2015, 09:25 PM | #11 |
C/10 junkie
It does look a little short. Let's see what Mel has and go from there. If his is the same $20 shipped sounds fine. Thank you
10-13-2015, 10:21 PM | #12 |
Shawn, sounds good, just let me know.
Thanks, Mark
10-14-2015, 11:51 AM | #13 |
C/10 junkie
10-14-2015, 04:35 PM | #14 |
Payment received, shift lever on it's way!
Thanks, Mark
10-14-2015, 04:49 PM | #15 |
You didn't end up giving me time to reply back and since I already took the pics this morning I will go ahead and post them. If your column is for sure from a 70 model then 70STOVEBOLT's pictured earlier style lever will fit and work, it will just be a little shorter. Here is what I would have available, both of these levers are OE used with nice finish, the top one pictured would be correct for a 70 (.385 thickness across flats) and the lower one would be correct for 71-2 (.465 thickness across flats) both of these are the later longer style levers, your choice $25. + ship cost. Mel
10-14-2015, 04:53 PM | #16 |
Hey Mel, what is the deal with the shorter one? I think it came with a 67 column that I got several years ago.
Thanks, Mark
10-14-2015, 04:57 PM | #17 |
