Old 10-13-2015, 05:37 PM   #1
ripper70
ripper70's Avatar
Exhaust kit for 4x4?
I am looking for an exhaust kit for my 70 4x4. I've got headers. Is there a kit out there that misses front drive line and transfer case? I can have a custom job done but id have to trailer it 60 miles 1 way and it is not running at the moment.Heartthrob said they only have kits for manifolds. Any help would be appreciated. Thanks
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline   Reply With Quote
Old 10-15-2015, 10:58 PM   #2
Re: Exhaust kit for 4x4?
I always have mine made, but I see your situation. What I do is get two pipes bent with back to back 45s like a 'z' so the bottom is even with the other top (2 1/4" offset if 2 1/4" pipe) and weld bell flanges on. I'd have to measure how far back the bends are. These will pass over your crossmember and you can rotate to clear transfer case. I have mine made of 5' lengths but probably do 3-4 next time. I lightly clamp a muffler on and drive to muffler shop.
You don't have those, so maybe you could have someone make them and send them to you. 3' would do, so shipping wouldn't be bad. Sounds like you have plenty of time before needing them
Old 10-18-2015, 07:03 AM   #3
1tuff71
1tuff71's Avatar
check hooker headers. they sell a kit
Bought this thing bone stock with intentions to just add a lift and tires and the next thing I knew it was on my garage floor in a million pieces. Sometimes the best laid plans........
1tuff71 is offline   Reply With Quote
Old 10-18-2015, 03:15 PM   #4
Mike C
Mike C's Avatar
Buy manifold kit. Cut off extra pipe and attach to reducers. That's what I did on my big block K30 because the only offered a small block kit. But it worked fine for me.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-14-2015, 09:04 AM   #5
1tuff71
1tuff71's Avatar
Took my own advice and got the kit from Summit and its going back. No fit and who the he#@ thought that this would work ???????????
Old 11-14-2015, 02:54 PM   #6
bmchevy1979
bmchevy1979's Avatar
What trans and transfer case are you running when I had the th350 in my k5 I had no problems until I put nova headers on it then it had to be custom made and with the sm465 in it now even with the truck headers the exhaust had to be made
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
