Old 10-13-2015, 08:15 PM   #1
Ta12sec
Gas tank?
Swapping an ls2 into my k5, wanted to use the entire factory fuel system but the tank isn't going to fit. What are u guys using for a tank? Are you having the evap system tuned out to avoid an engine light? Are you just plugging the purge valve line into the intake? And side note What are u guys getting for mileage?
Ta12sec is offline   Reply With Quote
Old 10-13-2015, 09:30 PM   #2
Robznob11
Robznob11's Avatar
Re: Gas tank?
Pull all that evaporated crap off, tune it out, run a camaro tank.02 model with vented cap . It takes some trimming and a hole through the frame for fill. Also need to remove the internal regulator out of pump
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-14-2015, 01:24 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Gas tank?
Fuel cells are so cheap these days, sometimes they are such an easy option. IMO, unless you need extra capacity, its easy enough to put a cell at the rearmost center of the frame rails. If you choose a cell, you also have the option of setting up a sump, dual feeds, a return, or any other components you choose.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-14-2015, 11:39 PM   #4
BigRed76
BigRed76's Avatar
Re: Gas tank?
I will second that. When I swapped in my 5.3 I used a square body blazer tank (25 gal). I had to move the rear crossmember, add an additional crossmember, and modify the filler on the tank. In the end I would've rather done a fuel cell.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
