Old 10-14-2015, 08:34 AM   #1
Ronw435
Ronw435's Avatar
2 or 4 barrel
Was wondering what everyone thinks about going to a Quadrajet and intake over a 2 jet Rochester for fuel mileage. I am going to have to buy a new carb which is going to be around 220.00. I tried to rebuild the 2 jet but the vacuum piston for the power valve is so bad I doubt that it ever pulls off the valve. I get about 8 miles per gallon and the exhaust will puke out black carbon onto the concrete. The plugs are also black. I has a manual choke and I have checked that numerous times to find it completely open. I have set the float to where there is no way of getting overflow. I have inspected the carb while running and find no evidence of overflow. It doesn't run too bad but it seems like I always have to be resetting the idle mixture. The motor will start and run first thing in the morning without ever using the choke. The truck is a 65 with a 283 and 3.07 rear end gears. The engine is basically stock except for a RV cam. It came with power pack heads. My question is would it be worth the trouble changing to the Qjet.
Thanks for any input
Ron
Ronw435 is offline   Reply With Quote
Old 10-14-2015, 08:46 AM   #2
PGSigns
PGSigns's Avatar
Re: 2 or 4 barrel
If you have a good one a Qjet is hard to beat.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-14-2015, 10:16 AM   #3
Ronw435
Ronw435's Avatar
Re: 2 or 4 barrel
Thats the problem, how to know you have a good one to rebuild when buying them used.
Old 10-14-2015, 11:13 AM   #4
morethanstock66
morethanstock66's Avatar
Re: 2 or 4 barrel
Just my .02, but you will most likely get similar MPGs. The secondaries on the 4 barrel will not open until the primaries are fully open. The 4 barrel will have more giddy-up when you need it, though. The engine is basically an air pump, you get a lot more flexibility with a 4 barrel. Keep in mind that if you have a 2 barrel intake, you have to swap to a 4 barrel one to get the 4 barrel.
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 10-14-2015, 03:21 PM   #5
Ronw435
Ronw435's Avatar
Re: 2 or 4 barrel
Morethanstock,
Do you know anyone in our area that is good at rebuilding a used Qjet?
Old 10-14-2015, 03:41 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 2 or 4 barrel
For what it's worth my mileage always improved when I got rid of a 2 barrel and swapped to a 4 barrel. It was easier to rebuilt and set up a 4 barrel, and easier to make adjustments as needed. Although many swear by them, I'm more of an Edelbrock/AFB guy than a Quadrajet fan. Those are just a pain to me. Edelbrock carbs are easy to change jets, etc.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 10-14-2015, 04:26 PM   #7
morethanstock66
Re: 2 or 4 barrel
x2, but I know people who are almost religious with their Qjets
Old 10-14-2015, 04:32 PM   #8
morethanstock66
Re: 2 or 4 barrel
Originally Posted by Ronw435 View Post
Morethanstock,
Honestly, no. The carbs that I have rebuilt, I did myself. Which mostly consisted of Edelbrocks and a couple Holleys. I would make a few phone calls, and you might be able to find one, typically older rod shops and mechanics. Sorry..
Old 10-14-2015, 04:46 PM   #9
Figuarus
Figuarus's Avatar
Re: 2 or 4 barrel
I've got a Q-Jet, and mileage wise, it's not a HUGE increase, but any little bit helps in these trucks.
remember to jet it for altitude in case you live in an elevated area.
just to give you an idea, I have a 283 with a TH400 behind it and am running 30" tires with a 4.11 rear end. I can get up to about 14 on the highway, and about 11 in the city if i'm gentle with it and cruise.
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 10-14-2015, 04:48 PM   #10
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 2 or 4 barrel
I believe Edelbrock makes quadra jet carbs still. Not sure. Even with a regular 4 barrel you'll get better mileage and power over the 2 barrel.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-14-2015, 06:38 PM   #11
AcampoDave
AcampoDave's Avatar
Re: 2 or 4 barrel
On my 283, I run a 500 cfm manual choke Edelbrock jetted 2 stages leaner in the cruise mode. I paired it with a performer e.p.s intake and I think it's great. Lots of members here put down on the Edelbrock carb, but I think that they provide an exceptional value with excellent tunability. Staying with the small one helps with my throttle response and a street driven 283 wont suck enough air for anything bigger. (I just had mine at over 9000ft above sea level last weekend and it still did okay. Just a few momentary light throttle bogs that went away as I accelerated.)
AcampoDave is offline   Reply With Quote
Old 10-14-2015, 07:18 PM   #12
WorkinLonghorn
WorkinLonghorn's Avatar
Re: 2 or 4 barrel
Ron
I sure would. Just go to the nearest self-serve junkyard and pull the manifold and carb and buy a rebuild kit. The kit will include instructions and there are write-ups here on this site to help if needed. It really is easy.
I rebuilt my quadrajet when I bought this truck in '96 and it is still working fine and I get 11-12 MPG mixed driving, 60 city/40 freeway and this truck weighs 5500 lbs. with tools etc. That is with 3.73 gears and an HEI type ignition and 60 MPH max.(usually!).
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
