10-14-2015, 01:35 PM | #1 |
Prop valve without reset button
Pol sells a brake prop valve for disc drum that does not have a reset button. Anybody use one of these? I'm on my 3 rd prop valve .... They all leaked at the reset button. Driving me nuts! They are Gm 172-1353 pv2
10-14-2015, 02:08 PM | #2 |
Re: Prop valve without reset button
That is a metering valve. From what I understand you need a metering valve on a disc/drum setup.
CPP sells just the metering valve for $10.00. I replaced my leaking prop valve and it's been great. You can also pull a gm prop from a junk yard. The new stuff is all made overseas, no way around it. |
10-14-2015, 04:18 PM | #3 |
I use one. It has never been a problem. If you need to reset it, remove the plastic warning switch on the top, re-center the piston using a plastic pick and re-install the warning switch. No problem!
