fuel tank interchange
I need to replace a fuel tank on an 84 k10. it had duel tanks. are they the same from left to right and how do I tell if its the 16 or 20 gallon tank. can I put a 20 in place of a 16 if need be? thanks guys.
Re: fuel tank interchange
If you have a long bed you can put a 20gallon tank in but it uses different full hoses if it's a shortbed it's a 16 an you can't put a 20 in
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
its a long bed. is there a way to tell what is in there now? do the mounts need to be moved?
#4 | ||
Yes, it is possible to put 20 gallon tank(s) in place of original 16's on a long bed. I believe the front mounts stay in the same location and only the rear mounts need to be moved. There should already be holes in the frame for the rear mounts to be moved to the 20 gallon tank location. And you'll also have to remove the filler pipe extensions and connect the hoses directly to the tanks. |
Post Whore
![]() Join Date: Aug 2014
how about take this opportunity to put in an aftermarket center mount tank in
LMC Truck got them - 20 gallon http://www.lmctruck.com/icatalog/cc/full.aspx?Page=50 |
this is a work truck. he wants both tanks. thanks guys for all the help.
