Old 10-14-2015, 08:17 PM   #1
Zach079xxx
Zach079xxx's Avatar
85 C10 removing oil pan
I had my abc 350 rebuilt about a month ago, ran great. I drove it to school 45 miles on the interstate at 70 MPH ran great but on the way home something came loose. Either my manifolds are rattling like a SOB or its my high volume oil pump. I've read the the inlet tube should be welded / locktite on, but I didn't install it and don't know if it was or not. I changed the oil today because it needed it, should've done it then honestly.. No metal was in it. I added the new oil and filter back in but now I'm thinking of draining it and pulling the pan to see if its my oil pump rattling so bad..
Can I remove it without with the engine in the truck? Again, its an 85 GMC C10 2WD
Whats the torque rating on the pan? Thanks guys
85' GMC Sierra Classic
Built 350; Weiand intake, Holley 600, Thumpr Cam
Built 350 turbo with shift kit & 2500 Stall
Thumpin' away
Zach079xxx is offline   Reply With Quote
Old 10-14-2015, 08:42 PM   #2
69heavychevy
69heavychevy's Avatar
Re: 85 C10 removing oil pan
I did it on my 69 and had to raise the motor 1/2" or so. Cross member dimensions are pretty similar from 67-87 so I'm guessing it would be the same deal.
I'm sure someone will chime in with a more definitive answer.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 10-14-2015, 08:59 PM   #3
Zach079xxx
Zach079xxx's Avatar
Abc lol I meant to say SBC up top, can't edit it now. Man that sucks.. I'm no mechanic and I wanna be able to do this but if the motor needs to be lifted I'm taking it to a shop.
Thumpin' away
Old 10-14-2015, 09:17 PM   #4
69heavychevy
It wasn't too difficult.
I had to unbolt the motor mounts and trans mount. Then lifted it at the harmonic balancer using a jack and 2x4.
If you dont feel comfortable doing it then I would recommend you take it to a shop.
Old 10-14-2015, 09:20 PM   #5
69heavychevy
Also why not take it to the shop that did the work? They should have some sort of warranty I hope.
Old 10-14-2015, 09:30 PM   #6
Zach079xxx
Zach079xxx's Avatar
Well, the guy is out of town until November. Something with family I believe he said. He built my engine and trans. If its something I can do without too much work, I'd rather get my hands a little dirty then lug it up to his place.
Thumpin' away
Old 10-14-2015, 11:15 PM   #7
f.monroe
f.monroe's Avatar
Are the lifters rattling? If so take the valve covers off and watch the rocker arms. Make sure they are all moving Correctly. Unfortunately thats probably about how long it takes to wipe out cam lobes if it wasn't broke in correctly by the guy that built it. Hopefully that's not the problem. Does it still have good power? If so it's probably not the cam.
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 10-14-2015, 11:40 PM   #8
Zach079xxx
Zach079xxx's Avatar
Sounds coming from underneath as far as I can tell, don't think it's coming from under the valve covers. Cam was broke in right, he told me how he went about it. Primed it and everything before turning the key. No loss of power, runs great just an awful rattle. Oil pressure is reading normal, 50-60 PSI because it's a higher up pump. Ran like that since the day I got it.
Thumpin' away
Old 10-15-2015, 04:32 AM   #9
80SPORT
80SPORT's Avatar
Very unlikely to be an oil pump issue.
Try to isolate noise while motor is running using a piece of pipe as a stethoscope.
If it is an internal contact noise a baffle in pan could be loose.
You could pull the plugs and spin it over and see if noise is still there.
Pull distributor and run oil pump with a primer if you still think it could be pump.(easier than pulling pan)
As Frank noted...lifters make clicking noises that can transmit thru the engine.
But have a very good look for a shroud or bracket on the outside.
And check harmonic balancer for damage or marks;I have seen them rub the crossmember.
Pull flywheel pan cover and check for contact or loose flywheel.
80SPORT is offline   Reply With Quote
Old 10-15-2015, 04:06 PM   #10
Hiluxxulih
Hiluxxulih's Avatar
You should be able to drop the oil pan without lifting the engine up , I removed mine to check the rod bearings , its the 305 but the 350 should be the same I would think .
1985 Chevrolet Custom Deluxe
4x2 , 305 v8 , 700R4 transmission
Hiluxxulih is offline   Reply With Quote
Old 10-15-2015, 10:16 PM   #11
Zach079xxx
Zach079xxx's Avatar
I'm gonna get up underneath tomorrow and take a close look and decide then. Thanks guys, wanted to have some other opinions.
Thumpin' away
Old 10-16-2015, 12:01 AM   #12
bigblock73
yeller
bigblock73's Avatar
Oil pans, from small block to big block on 73-87's, can be removed by simply removing the pan bolts. I recommend using the fel pro one piece gasket...makes the job much easier.
bigblock73 is offline   Reply With Quote
Old 10-16-2015, 12:19 AM   #13
Zach079xxx
Zach079xxx's Avatar
I bought a fel pro engine gasket kit before doing the build. It does indeed have a one piece gasket. Is the torque for the bolts 12 pounds? That's what I've seen online.
Thumpin' away
Old 10-16-2015, 01:59 PM   #14
Zach079xxx
Zach079xxx's Avatar
Before digging into the oil pan and dealing with that mess, I took my sisters stethoscope and creeped underneath while it was running. Oil pan no noise, tranny no noise, bell housing NOISE. Correct me if I'm wrong, but the cover that covers the flywheel/flex plate whatever you wanna call it and the torque converter. Took that off and it was fine! No noise. Looked at it and my flywheel was grinding it, took some paint off and it's bent. Where can I get a new one? What's the real name, if I'm getting it wrong? Dust cover/plate? I'm a happy guy right now.
Thumpin' away
Old 10-16-2015, 05:42 PM   #15
77 Big 10
77 Big 10's Avatar
Inspection cover has been the name I used.
Paul
77 Big 10 is offline   Reply With Quote
Old 10-16-2015, 08:06 PM   #16
cadillac_al
I'm sure it can be straightened to work good enough.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-16-2015, 10:01 PM   #17
Zach079xxx
Zach079xxx's Avatar
I'm going to straighten it paint it and install it back in, if the noise comes back I'll know to check it and see if paint is missing. Thanks guys
Thumpin' away
Old 10-16-2015, 11:45 PM   #18
80SPORT
80SPORT's Avatar
The General calls it "cover,trans conv"
Old 10-17-2015, 12:46 AM   #19
Zach079xxx
Zach079xxx's Avatar
Thanks. I'll be buying a new one or going to the junkyard if this one acts up again!
Thumpin' away
