10-14-2015, 09:28 PM | #1 |
Mustang II Steering C Notch
In the process of doing the c notch for my 1950. Was curious to see what you guys did for the steering rack clearance. The directions say 5" from the center of the crossmember but that seemed way too far forward. Here's what I have now. Basically looking for pictures anyone may have.
10-14-2015, 09:29 PM | #2 |
Re: Mustang II Steering C Notch
Another shot
10-14-2015, 11:21 PM | #3 |
Here's a couple pics of mine (this was set-up years ago) don't have any with it painted...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
10-15-2015, 01:26 AM | #4 |
So you pretty much cut the c notch pretty close to the crossmember right? I just feel like I cut mine really close to it but it looks similar to yours I guess.
10-15-2015, 11:45 AM | #5 |
if you measure the distance from the crossmember to the centreline of the steering rack, then you mark the frame forward of the crossmember that same distance, that will be the centre line of the c notch cut away. follow?
10-15-2015, 03:46 PM | #6 |
bolt your rack up to see
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-15-2015, 11:08 PM | #7 |
As Ogre says, bolt you rack up, then take the arm and more forward as far as it will go, then backward as far as it will go. If the rubber boot doesn't touch, your good to go
10-15-2015, 11:10 PM | #8 |
6>8 Plugless........
You could do the same as who ever did my 40 Ford's frame.......... Cut the front frame horns off and move them up 2"............... Yeah, quality. not! Don't do it that way. Haha
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
10-16-2015, 06:36 PM | #9 |
What "c notch"
yoshi's 49 project |
10-17-2015, 03:15 AM | #10 |
10-17-2015, 03:15 AM | #11 |
10-17-2015, 11:28 AM | #12 |
if your rack is still hitting the frame, you need to cut clearance for it
no good pic of mine from the side, my notch is further forward like oldman's yoshi looks like he used actual mustII parts with the strut rod as long as the rack doesn't hit the frame with the suspension bottomed out he's good to go
10-17-2015, 08:52 PM | #13 |
10-17-2015, 11:32 PM | #14 |
Does anyone know how far forward the heists boxing plates are supposed to go? I have seen them pushed all the way forward and others with a gap in front of them so the c notch is only partially attached to the plate. Suggestions?
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
10-18-2015, 03:29 AM | #15 |
I'm using TCI IFS, bought in 2001, instructions are better these days, see attached link, maybe this helps.
http://www.totalcostinvolved.com/pdf..._Front_End.pdf |
10-18-2015, 10:12 AM | #16 |
As far as I can remember, they did not go all the way to the front crossmember of frame. After I had my c-notch in place I made a filler piece to reach the crossmember...Jim
10-18-2015, 03:59 PM | #17 |
Grabbed this one for you. It is at a bit of an angle as I didn't remove the tire.
10-18-2015, 11:07 PM | #18 |
10-18-2015, 11:09 PM | #19 |
Great picture thanks, did you trim off that tab area on the radiator support? I don't know that I can describe it but yours has a lot of room in from of that steering rack against the frame.
Here's what im meaning. Last edited by 392Hemi; 10-18-2015 at 11:16 PM. |
10-19-2015, 03:57 AM | #20 |
I had to trim it
Also had problems with the rack and joint hitting the crossmember. |
10-19-2015, 09:16 AM | #21 |
392, I also cut mine off, you can see in my pic on post #3 first pic...Jim
10-19-2015, 10:51 PM | #22 |
Cool, well I didn't know I had to use the .75" spacers on the rack so that made my measurements change :/ lol Had to cut some more up front and also trimmed the radiator support chunk like you guys said you did. I got one side completed today with the filler piece as well so some good progress.
10-19-2015, 11:21 PM | #23 |
392, progress is progress...Jim
10-27-2015, 02:12 AM | #24 |
Well I got the c notches and welding all done. Not too shabby for young guy with a grinder and a sawzall haha now I just have to figure out how to build this suspension. Was pretty disappointed it came with no torque specs or instructions.
10-27-2015, 10:57 AM | #25 |
392, here are some instructions for a MII install. These are just general instruction from this company, but should help out...Jim http://www.southernrods.com/instruct...structions.pdf
