10-15-2015, 09:28 AM | #1 |
70+ ( Old Skool Club )
Thinking about a mild drop
My 72 C10 has the factory trailing arm suspension with the Auxiliary Rear Spring ( RPO G60) and my question is, if I went to a 2 1/2 inch front spindle drop with a 4 inch dropped rear spring with a Hellwig bolt on rear sway bar would I have to remove my Auxiliary Spring from the truck?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
10-15-2015, 10:02 AM | #2 |
Re: Thinking about a mild drop
Yes, I would remove those springs, as they were intended for an overload spring. When the suspension drops, due to an increase in load, the trailing arms will contact the spring. When installing the lowering springs, it will more than likely put that trailing arm in contact with the overload at ride height, and would cause a harsher ride because of it.
10-15-2015, 10:09 AM | #3 |
Thanks for the quick response.
