Cab Pics request - manual trans shifters & seating
I'd be interested to see where people have fitted non-stock transmissions, the changes they've made to their cab -bucket seats, shifter position, trans type?
I did have a look but if I have missed an existing/old thread please set me straight ![]()
'63 C10 Longbox fleetside '94 C1500 Sierra ex-USAF beater |
Senior Enthusiast
Re: Cab Pics request - manual trans shifters & seating
Here's a shot of my interior. The powertrain is a 350 Chevy with a Richmond 4 speed under a high hump floor. The shifter is a Street Super Shifter which mounts the unit high up with straight shift rods, although I'm running a conventional handle, and ProCar bucket seats:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Wow that is some cab! What's the heater unit from? So, the Richmond - shifter position similar to an m20/21/22 etc.?
Here's mine with a 4 spd Saginaw and old school Nissan pickup seats with the headrests removed. The floor is a low hump and the shifter is a Hurst.
#5 | |
Senior Enthusiast
The shifter position was essentially the same as where a Muncie would have placed it with a stock Hurst shifter. The Street Super Shifter moves the shift housing up into the shift boot, and several inches further to the rear.
![]() Join Date: May 2007
non stock? ok.
NV1500 5 speed coreshifters short shift and 16" hurst stick. in a perfect world it would be 3-5" further back. ![]()
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#7 | |
Really interesting to see how people have modified their cabs ![]()
I take it that would be so that you could shift gears more comfortably or use a shorter shifter for less throw? The position at which the shifter comes through the floor looks pretty close to the 420 trans. I wonder if that is the case for all the new venture transmissions?
![]() ![]() Join Date: Jul 2002
on my 64 with a Saginaw 3 speed from a 69 C10, the emergent brake cross member interfered with the shift linkage, so it sets back a bit further, which means it would not clear the bench set. I put in buckets from a 98 C1500 pickup (very comfortable). Shift linkage is the Hurst Indy for a 69 C10 truck, with a old handle from something (Mr Gasket I think).
The Billert piston shift knob was just added last week.
#10 | |
If I do another swap like this, I will move the motor back. there was another hurst bench seat shifter I loved but could not use because the stick would hit the dash in 1-3-5
'98 Chevy 60/40 cloth split bench. NV4500. The shifter sits back 8 or so inches from the original shift tower hole. 2nd and 4th gear put the shifter about 1" away from the front of the seat. I really want to shorten the shifter 3-4" but haven't had the time yet.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
I have a factory bench seat in my 1065 C10. Here's my T5 with an S10 shifter position and no adapter plate and the cast iron bell is in the factory location.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#13 |
I have a sagniaw 4 speed and factory bench seat using Hurst shifter lever for a 55-57 Chevy car works good try get pic tomorrow
#14 |
Here's mine. Sm420 with a seat off of a 01 F$#D pickup. With behind the seat gas tank in stock location. Plenty of room for 2nd 4th and reverse.
Well that didn't go as planned. 1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6 |
#15 |
Not true. Factory bench seat and tail shaft mounted Hurst Mastershift II on my borg t-16 HD 3 speed
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#16 |
Some real inspiration here. Thanks for sharing.
#17 |
Factory seat with a TKO 500 mid shift location (high hump).
64 Step Side - The Mistress |
#18 |
66 GMC factory buddy buckets ( recovered ) with T10 4 speed
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
