Old 09-14-2003, 12:46 AM   #1
gman
Where to buy breather hose
Anyone had any luck finding a preformed breather hose like the original one that came on the truck? Truck is a '72, 350, 4barrel...........the hose is "L" shaped but no luck finding one at Napa, local ma & pa store that "has everything" or anywhere else. Any ideas? Maybe something from another vehicle? I don't know.
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air
2000 Harley...Wide Glide
gman is offline   Reply With Quote
Old 09-14-2003, 10:08 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Grab some hose from the local part's store and run the line up to the frame real nice like .... Unless you are going for a total restored look?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-14-2003, 10:46 AM   #3
Locutus
Locutus's Avatar
Take your old one up to your parts store and ask if you can look thru there hoses. See if you can find one that has the right curves to it but that you can cut off any excess.
Locutus is offline   Reply With Quote
Old 09-14-2003, 05:17 PM   #4
john
member #16
john's Avatar
If you are talking about the one that goes to the air cleaner, I went to NAPA and got one off the rack. I think it was a 3/4 in. 90 deg. hose for a cooling system. Cut both ends to fit like origional hose.
john is offline   Reply With Quote
Old 09-14-2003, 09:42 PM   #5
gman
Thanks! I'll try and find a hose that I can cut-to-fit.
Old 11-08-2015, 07:58 PM   #6
CastIron
CastIron's Avatar
Re: Where to buy breather hose
I'm reviving an old thread to see if anybody has found a good source for the breather hose going from the air cleaner to the passenger side valve cover. The hose is 23/34" (or 3/4") inside diameter with a 90 degree bend on one side. I've tried 3 local parts stores today, and the best they could do was offer me 3/4" heater hose and some elbows. I don't think heater hose would hold up for long without either swelling or drying up and cracking. Any ideas?
CastIron is offline   Reply With Quote
Old 11-08-2015, 08:49 PM   #7
9teen69
9teen69's Avatar
I believe Classic Heartbeat has them.
http://www.classicheartbeat.com/default.htm
888-338-2502
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
