10-16-2015, 12:55 PM | #1 |
Gasket O-Ring identification
I pulled my engine, tranny, T-case out of my 85 K2500 and I could use help in finding the right gaskets and O-rings to use with the TH400, T-case adapter and NP208 T-case.
Currently there is an O-ring between the Tranny and adapter plate and a gasket between the adapter plate and NP208. Does this sound right, or should there be a gasket and O-ring between the tranny and adapter plate? Also, how do I clean this before re-installing? Should I just use ATF to clean any debris off the shafts and mating surfaces and re-install, or should I use an actual solvent to clean the mating surfaces and shafts? Thanks in advance for the help and for the great site here Robert
Robert 1975 C10 - Huckleberry 2007 Jeep JK - John Wayne Jeep Smittybilt front/rear bumper, 10K winch Pacific Grove, CA |
