Old 10-17-2015, 08:03 AM   #1
OldChevy61
OldChevy61's Avatar
62 c/10 ball joints
I'm trying to install the upper ball joints in my 62 a arms. I assume the rubber boot that is attached needs to stay attached to the upper part of the ball joint. Problem is it won't slip in the hole far enough,basically to tight. I cleaned all the paint off with a dremel,still to tight. Maybe some grease on the rubber boot? Lacks about 3/4 in sitting all the way down. I just don't want to damage the boot.
OldChevy61 is offline   Reply With Quote
Old 10-17-2015, 11:22 AM   #2
slepysal
slepysal's Avatar
Re: 62 c/10 ball joints
I didn't run into that when I did mine. Can you post a picture of it?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 10-17-2015, 11:26 AM   #3
62gmcsbc
Okay just did this last night, take the rubber boot off carefully by prying it off, you may need a knife to separate the lip from the ball joint, then insert the rubber boot first from the top of the ball joint opening in your arm, then insert your ball joint! It will fit without pinching the rubber boot!
62gmcsbc is offline   Reply With Quote
Old 10-17-2015, 12:48 PM   #4
OldChevy61
OldChevy61's Avatar
Thank you sir. One and done,lol. Took about 5 mins each. That's why I love this site. Somebody always has the answer.
