Need advice on Restoring Guage Cluster 63'
Just got a 63' Guage cluster that's warning lights. I'm trying to keep my truck original but still functional to modern specs. Anyways, I want to restore this cluster, mainly my question is about the fuel guage, is there any way to restore these at home, or do I have to send it off somewhere to a professional? Also my second question about the lens, I wish I could find a glass replacement, is there any way to clean these plastic lenses up and make them look brand new? Thanks!
![]() Join Date: Jan 2011
Re: Need advice on Restoring Guage Cluster 63'
The fuel gauge you can check with a volt meter and see if it is good. You can then carefully clean it. I use air and electronic parts cleaner if needed. The lens can be cleaned on the gauge side with a good car wax. Just do not rub on the lettering to hard. The fronts I use a Maguires head light restoration kit with the sanding pad and the buffer. Follow the instructions and it works pretty good. Just take your time. The plastic cleaner in the kit does a good job on the small light lenses. There is a cluster restoration thread in this section that shows doing a 64 to 66 cluster but it gives good info on paints and colors for the rest of the job.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#4 | |
