My "new" <$300 rebuilt 307 (1 min video)
I know you guys like clips...
1965 C30 pickup 350/SM420/4.10's (daily driver) thread 1968 Impala 4 door sedan (future driver project) thread Last edited by 66Submarine; 10-19-2015 at 01:11 AM. |
![]() Join Date: Jan 2013
Re: My "new" <$300 rebuilt 307 (1 min video)
Sounds healthy.
Aaron 1964 K10 1964 C10 1965 Suburban 2005 Yukon |
#3 | |
![]() Join Date: Aug 2013
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Nice sound.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Post Whore
![]() Join Date: Mar 2013
Sounds good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Sheee-it...imagine what it would sound and run like if he spent $600!
Nice work! ...ned.
'63 C10 long wide; '61 Corvair Lakewood; '74 BMW 2002tii; '89 BMW 325i, '49 Ford 8N |
That thing sounds sweeeeeeeet!
66 Custom Camper 327/ 4 spd. Bone Stock, down to the split rims |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yes that 307 does sound good
![]() Now we need to know some specifics on what you did to it ![]()
![]() Join Date: Oct 2006
x2
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Thanks, guys.
It's the 307 out of my '68 Impala with 98,000 on it. I took it apart, cleaned it up, honed it, replaced all the bearings, new brass freeze plugs, moly rings, steel shim head gaskets for correct quench distance, double roller timing chain (to replace the BS nylon one with the nylon all shucked off), new oil pump, quickly smoothed the heads up a little with a die grinder (made me feel better?), and used a mild Elgin E860SM GM blueprint HO 305 cam (202/207@.050, 114LSA, .404/.414). The Holley 600 and Performer RPM intake were already on it when I got the car, and some short GM chrome valve covers I had and a couple cans of Duplicolor DE1607 made it look less hideous. I used a HEI I had with some light advance springs and ended up with 20º inital for 36º total + 14º from an "AR-12" vacuum advance can. It's just a very mild and inexpensive "build" that runs nice and should last a long time. It makes 16.5" of vacuum at idle and I haven't noticed any detonation on 87 octane. The exhaust is some old 1.5" truck headers and dual 2.5" pipes (eventual BBC power?) kicked out in front of the rear tires with Summit turbo mufflers. So far no one has said it's too quiet... ![]() It also did this the other day warming up: Apparently the factory carb jetting was way too lean (it hesitated pretty badly and the plugs looked like they were never ran in anything). Swapping the 65's out for some 68's yesterday made it run much better (still need to check what the WOT jetting is like). I also swapped the orange accelerator pump cam and 31 nozzle out for the smaller white cam and a 25 nozzle. |
Sounds great. I just popped a 307 into my burb. May have to go for a cam too...
![]() Join Date: May 2007
healthy!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
