10-19-2015, 07:56 AM | #1 |
A/C cable routing help
I screwed up and didn't identify where my cables on the A/C controller go. I looked but only found heater routing. Does anyone have pictures or a diagram of where they go? Thanks
10-19-2015, 10:41 AM | #2 |
Re: A/C cable routing help
Fairly easy if you know what each door is called. Hopefully, this helps:
Defrost lever/cable (top slide control) goes to the metal box to left of the "S" duct. This is the box that directs heat onto the top of the transmission tunnel. Outlet lever/cable (middle control) goes to the diverter box located directly to the right of the "S" duct. The diverter box is the one that has all the vent duct connected to it. Temperature lever/cable (bottom control) goes to the blend door on the heater core housing. There is a cartoon on page 1A-8 of the service manual that might help. Hope this helps. Last edited by Davidf; 10-19-2015 at 10:47 AM. |
10-19-2015, 10:43 AM | #3 |
That is it. I wasn't sure what everything was called. That really helps. Thanks a bunch.
10-19-2015, 10:45 AM | #4 |
