Old 10-19-2015, 09:11 AM   #1
bigmac73
bigmac73's Avatar
easy install??
would this be an easy install , I am assuming just get the LS engine mount kit, and a electric fuel pump ?? would I need some kind of stand alone controller???
this would go into a 72 C-10
http://www.blueprintengines.com/inde...es-psls4270ctc
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-19-2015, 12:33 PM   #2
PGSigns
PGSigns's Avatar
Re: easy install??
Not quite that easy. Will need a bigger than stock fuel line, a radiator for the LS engine, All the accessories for the front, Headers and exhaust to fit the LS, Then decide what you want for a trans and what you have to do to make that work with an LS. And thats just a good start.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-20-2015, 11:22 AM   #3
Hart_Rod
Hart_Rod's Avatar
Re: easy install??
You can buy a complete motor/transmission/wiring harness from GM for that price: Connect and Cruise....
Hart_Rod is offline   Reply With Quote
Old 10-20-2015, 04:59 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: easy install??
x2
Its hard to argue with getting the product from the horse's mouth so-to-speak. They cost a pretty penny, but I have yet to hear of anyone getting a "bad" one from the CnC packages, or even the E-Rod for the cali guys.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
