LS engine and radiator fans
Hello,
I have a 2001 5.3L engine in my truck and a 180 degree thermostat. The truck has two radiator fans and the wiring is setup for air conditioning although I have not installed the a/c yet. The car's radiator Fan 1 won't kick it until the temperature hit 200 degrees (give or take) and since I will be towing a lot, this is nerve wrecking. Is there any way that I can use a manual switch on Fan 2 to turn it on as I please? What is the best way to do this? Thanks |
meowMEOWmeowMEOW
Re: LS engine and radiator fans
If you really just want a manual switch, then run the fan 2 lead to a switch in the cab. Otherwise, you can just have the temp limits changed in the tune and engage the primary fan earlier and/or engage the 2nd fan. Fan control 2 doesn't HAVE to be used for the A/C.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Post Whore
![]() ![]() Join Date: May 2015
My ecm was originally setup for only one fan so I had to have num 2 fan added to it but they set my first fan to come on at 150 and 2nd fan comes on at 170 and i have a 160 thermostat....it will run all day at 160- 170..towing , hot weather, etc..
Mongo, what part of alabama are you in? If you are around BHM, who did the tuning?
meowMEOWmeowMEOW
Keeping cooling is important, but keep in mind guys that you can actually keep a motor too cool. LS motors are designed to be run hot, hotter than normal for traditional small blocks. While not doing any damage, you aren't gaining anything in terms of performance or engine safety by doing so.
#6 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Yeah, thanks all. I would like to see it run between 180-195 and my danger zone being 200 and above. I know some people have reported their LS based engine to run over 220 and being fine but I am somewhat old school, gauge goes over 200 and I am pulling over, lol. Homemade, PM in the works!
#9 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Post Whore
Aruba1..I am north of cullman, about 60 miles north of you up i65..the guy I got the engine from unlocked the ecm ,and why i dont know but he put a 4.8 tune in it,but the final tune was done by a guy near huntsville and he put the correct tune in it for a 6.0.there are several guys around here local that do ecm tunes now.
As far as how cool mine runs I pulled what I assume is the factory thermo 1. To fill the block with antifreeze 2.to see what temp it was before I ever cranked it and it had a 160 in it..I don't know if it makes a difference but my 6.0 engine came from a escalade with 107000 miles on it so i dont think its been changed,so I left it as it was..i did put a new one in it while i had it out but stayed with the 160..at the parts store they showed a 160 and a 180 for my engine..and its a might warmer here in Alabama summertime than up north so I didn't think it would hurt for it to run cooler. |
Old member
I just got home from looking at new 2015 Silverado's. I've been thinking about trading my 08 Tahoe in on one. My 08 Tahoe is factory stock LTZ nothing has been touched on it with a 5.3 and it runs 210 all day everyday weather I'm towing are just cruising!
Running these motor's at 165 are anything less than 190 is hurting you on MPG! These motor need to run with in the parameters they where designed for which is 210. As long as you keep the trans temp below 200 you are good to go. I wouldn't want mine running any less than 190. Just some info on the new 5.3 that I looked at. They all had electric steering and the water outlets are on the drivers side now so a swap will be much easier as far as hoses. The intakes are car types now also! ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
