Old 10-19-2015, 02:31 PM   #1
wilbur46
wilbur46's Avatar
brake line wrenches
Hi guys,
My line wrenches suck. They all flex. I don't want to replace all my lines because some crap tool won't loosen fittings.
I have a Crew Line, a Craftsman, and a Mac.
Anyone have one that always works, and does not flex?
Thanks, W
wilbur46 is offline   Reply With Quote
Old 10-19-2015, 06:40 PM   #2
vince1
Re: brake line wrenches
I think they are called flare nut wrenches in case it helps to research them.
Kroil is a pretty good penetrating oil if allowed to soak for a while.
vince1 is offline   Reply With Quote
Old 10-19-2015, 06:45 PM   #3
michael bustamante
michael bustamante's Avatar
ive never had a flare wrench that didnt give and want to round the flare nut. if you find a good set, post it on here
1967custom
michael bustamante is offline   Reply With Quote
Old 10-19-2015, 09:30 PM   #4
jdl71
jdl71's Avatar
When they are that rusted up, stuck, whatever I'm not sure there is any wrench that will loosen the nuts without some rounding. When I did my brakes I got about half loose with a flare wrench, the other half I ended up cutting the hose and/or line and using a 6 point socket. Careful use of some heat (propane not acetylene) would likely help also.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 10-19-2015, 09:33 PM   #5
jtrichard
UNLESS your lines are VERY good or almost new.. flare nut wrenches may or may not work a good pair of real (IRWIN) vice grips work about the best when the wrench wont
jtrichard is offline   Reply With Quote
Old 10-19-2015, 10:13 PM   #6
T and S
T and S's Avatar
I have a set of craftsman flare wrenches, they work just fine. If nuts are super tight are rusted they will round off the corners just like any other wrench.
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 10-20-2015, 07:01 AM   #7
BigDan3131
BigDan3131's Avatar
2nd on breaking them loose with vise grips.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 10-20-2015, 09:13 AM   #8
cg285
aahhh! lose the vice grips. trick is to tighten them first before loosening. and if after that they are that tight/corroded then they're trash anyway
cg285 is offline   Reply With Quote
Old 10-20-2015, 11:47 AM   #9
VictoriaHardware
VictoriaHardware's Avatar
I have ALWAYS gotten them loose with propane when rusted bad.
VictoriaHardware is offline   Reply With Quote
Old 10-20-2015, 12:07 PM   #10
61K10
61K10's Avatar
I had one that was extra wide years a go, worked good. who knows where it is now lol!
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-20-2015, 02:23 PM   #11
MikeN
MikeN's Avatar
X2
If they're seized so bad a Craftsman flare wrench won't loosen, vice grips are likely your only option, and they will pretty much ruin the hex nut.
MikeN is offline   Reply With Quote
Old 10-20-2015, 03:43 PM   #12
Brad54
Brad54's Avatar
My standard Craftsman wrenches flexed and opened up.
My polished Craftsman Professional wrenches never did.
I also have a set of vintage Snap-on wrenches that are awesome... these are the old square-panel style, not the new full-polished ones.
They show up on ebay pretty regularly.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 10-21-2015, 04:48 PM   #13
donthekawguy
donthekawguy's Avatar
I have a set of Kobalt from Lowes that have done me right.
66 shorty
donthekawguy is offline   Reply With Quote
Old 10-22-2015, 04:55 PM   #14
short&wide65
-Brad
Agreed. Mine are the older Snap On ones and they are pretty awesome.
1965 GMC 910 Short Fleetside.
short&wide65 is offline   Reply With Quote
Old 10-22-2015, 05:56 PM   #15
wilbur46
wilbur46's Avatar
Thanks for all the replies.
I looked again and all of my wrenches are beveled in from each side.
In other words, they don't make full contact with the width of the nut!!!
I'm now looking for some non beveled ones.
Also, I'm working on brass flare nut into a brass T. So-- no rust problem.
(It is the T for the rear line so I don't want to cut it and have to replace the whole shebang).
Old 10-22-2015, 06:14 PM   #16
bhc41051
bhc41051's Avatar
Irwin Vise Grips are a shadow of their former self, I'd look for Peterson Vise grips on eBay.
bhc41051 is offline   Reply With Quote
Old 10-22-2015, 06:43 PM   #17
donandal
I have used this style vise grip with great success...
works without messing up the hex
donandal is offline   Reply With Quote
Old 10-22-2015, 08:10 PM   #18
wilbur46
wilbur46's Avatar
Great googooly!!!
I actually don't think I have ever seen a set of vise Grips like that.
I'm gonna get me some!
Thanks for posting.
By the way, I originally said i also had Mac, but they are actually Snap On.
I just looked at Mac and they appear to be flat sided, in which they would have a lot more grip on the nut. I wonder if they flex?
Regards, W
Old 10-23-2015, 12:53 PM   #19
MikeN
MikeN's Avatar
My Craftsman line wrenches are near 30 years old. Maybe the old ones are just better? Anyway, never had any problems with them. Work great.
Old 10-23-2015, 03:30 PM   #20
Hugh in NC
Hugh in NC's Avatar
I am doing a dual master cylinder install right now and have been doing the required changes on the brake lines. I had purchased a new set of Kobalt wrenches a few months ago (after my last brake work). The Taiwan Great Neck wrenches are way too thin and will not hold under pressure. I had only 1 Blackhawk mm wrench. The Kobalts compare very closely to the Blackhawk as far as thickness and beefy around the end of the wrench. The Kobalt is a short wrench and I could not get the leverage to break the lines loose. A 12 inch piece of pipe over the end of the wrench broke the fitting loose without any problem. I think the Kobalt is going to do the job okay.
Hugh in NC is offline   Reply With Quote
Old 10-23-2015, 06:07 PM   #21
gar187er
old craftsman the best, some of the newer stuff is made in china, probably along side harbor freight tools!
gar187er is offline   Reply With Quote
Old 10-30-2015, 07:44 PM   #22
wilbur46
wilbur46's Avatar
Spent a week checking out different wrenches.
(after I finally got my fitting loose)
Mac makes their wrench slab sided, which means it has about twice as much contact area on the flare nut.
I got one.
Anyone who has the same trouble needs a flat sided wrench.
The others that were beveled on the sides I junked.
Thanks for all the comments, W
Old 11-01-2015, 03:23 PM   #23
kingchr
For what it is worth I use a set of cheap Harbor Freight Wrenches. If there is room I will clamp a set of vise grips onto the outside of the line wrench that is on a stuck fitting. This makes it MUCH harder for the wrench to stretch out of shape.
Have a good one,
Christopher K.
kingchr is offline   Reply With Quote
Old 11-02-2015, 06:44 PM   #24
wilbur46
wilbur46's Avatar
Its interesting how many comments this thread got. I guess everybody hates bungled brake line fittings.
One thing I did mention at the beginning is that dealing with the flex lines is way different than the brass fittings.
I never have much trouble with the flex lines because they have steel fittings and you can crank on them and use heat.
Screwing with old brass fittings is way harder, and for this job, I did not want to replace all the hard lines.
I finally got it done with a borrowed Mac flare nut wrench and also used the weird vise grips mentioned earlier in the thread.
They were actually perfect for already bunged up fittings.
Dual cylinder power drum brakes. Yea! TCI $120
W
